Results 1 to 8 of 8
Thread: First time out at the track?
    Here is the best guide I've seen so far for track day n00bs. Essential Reading. Seriously. If you've ever even considered taking your car out on the track...this is for you. Lots of pretty pictures and diagrams.
    PDFs in two parts:
    http://gvc-bmwcca.org/drivingschool/...hronicles.aspx
    ...And yes, this post absolutely belongs under Performance Tuning.
    Feb 2007
    347
    Wow renn, i've learned so much from this!! It's definately worth a read, even if you're not planning to go to the track!!
    If you don\'t do it properly, don\'t waste our time!!
    The C280
    1995 C280
    1987 MK2 GTi 1800 8v
    Very informative,i learned DOT5 brake fluid is silicone based and isnt suitable for ABS systems because it doesnt contain glycol thus doesnt lube the ABS pump properly....err is this so for the 202 pretty sure i put dot 5 in there last time=)
    gr8 post
    Awesome read.
    I gotta Sticky it.
    Good Stuff AJ
    4
    Hey speedybenz where did u get ur headers/LSD?
    Nov 2012
    Cambridge ON. Canada
    1
    Does anyone have a new link to this article?
