Results 26 to 50 of 59
Thread: Blown Engine?
    1,069
    yea my uneducated guess would be maby bent valve or head gasget.
    A good next step foward to eliminate any major engine damage is to get it compression tested, this is relatively inexpensive and may tell you what you need to know,
    as well as what someone mentioned about the if air is leaking out your radiator cap
    -Logan-
    Oct 2006
    1,322
    I think theres no compression, won't know till the end of today. Its at the stealership as we speak *just hooking it up to the computer*. At low rpm's theres a stall. I'm just praying its either a valve, or head gasket, i'll been even happen if its just both. I already know 1 of the lifters are bad, or need adjusting.
    Dec 2006
    Norcal
    2,864
    ... I smell fried piston rings .. Mmmm ...
    im sorry but that just sucks.
    white 97' C230 (sold)
    white 94' C280 (sold)
    white 98' C43 (sold)
    Tektite 03' E55 (sold)
    Black 86' Porsche 951 (sold)
    Black 98' C43 (sold)
  4. #29
    Feb 2007
    Boston,MA
    545
    WOW you want it to be a bent valve or bad gasket you know how much that cost wow i get pissed every time i put gas it my car
    Mercedes
    Engineers
    Racecars
    Carfully
    Economically
    Drivability
    Even
    Safety
  5. #30
    Any word yet?
    \'94 C220
    Black.
    Chaos reigns within.
    Reflect, repent, and reboot.
    Order shall return.
  6. #31
    1,069
    haha what a comment to sum it up.
    i love it nelson
    -Logan-
  7. #32
    Feb 2007
    Boston,MA
    545
    Seriously every time somthing happens to my car all i hear is that sound that slot mechines make at a casino that ding ding ding sound
    Mercedes
    Engineers
    Racecars
    Carfully
    Economically
    Drivability
    Even
    Safety
  8. #33
    Oct 2006
    1,322
    Well Here is what Mercedes Benz said.
    80342 Verified Fires but stalls, checked fuel pressure ok, R+R #1 spark plugs and checked found ok but are denso iridiums, checked compression on #1 cyl. 145#'s. SDS short test multiple codes for trottle actuator and air intake bypass flap. also misfire codes and codes for maf sensor. *this is what made my day* CLIENT HAS RELOCATED MAF SENSOR ON INTAKE PIPE LMFAOOOOoO, checked actual values found key on values for throttle actuator to be 8.2 degrees out of spec, talked to throttle actuator but got no respones, reinitialized throttle actuator, now vehicle will run, but not very well. Has multiple intake leaks due to aftermarket intake setup, Supercharger is not kicking on, Needs new throttle actuator to start and may need new MAF sensor and put back into stock location
    MAF i orderd allready, where can i find the throttle actuator. Thats the T-body right?
  9. #34
    Feb 2007
    Boston,MA
    545
    ya i think its the little electric motor that moves the throttle plate
    Mercedes
    Engineers
    Racecars
    Carfully
    Economically
    Drivability
    Even
    Safety
  10. #35
    Jan 2006
    1,058
    >>N E way i was spraying on a mustang<<
    Heh... every time I read this thread and read this first sentence it sounds like you were some male cat marking his territory. "There's Cru again pissing on another Mustang..."
    1999 C230 Kompressor
  11. #36
    Oct 2006
    1,322
    does the compression look right to you guys.........lol does any of the information look right. i mean from everything i discribed to you guys, does it really sound just like i need a MAF and a new T-body
  12. #37
    Oct 2006
    1,322
    lmao thats what happens when you work for ford, and just hate ricers....LMAO i get shit all day long driving a benz. Gotta prove my self some how
  13. #38
    Senior Member Logic's Avatar
    May 2007
    Colorado
    1,428
    leaks in your intake? is it on the cold intake side ? or where the mass air flow sensors is ?
    98 C43 AMG (SOLD)
  14. #39
    Oct 2006
    1,322
    lmao beats me, i think they pulled up a old code that happened wayyyyyyyyyy before i got the CAI
  15. #40
    Mar 2007
    1,122
    hey cru, how much did the dealer ask for everything? just curious
    1999 Silver C43 AMG
    Current Mods:
    Soon to come:
    ECU Tune
    Mabuhay!
  16. #41
    Oct 2006
    1,322
    i don't know acutally, i figured that would be a easy ass fix, only 4 - 5 screws and unplug and plug that vacumme line and wires. I know the acuator is about 900 bucks at the dealer, and i figured about 1 hr of labor
  17. #42
    Dec 2006
    Norcal
    2,864
    im not 100% sure but a new throttle body may need to be programmed to your cars spec. id have your car plugged to an SDS agian after you think you have fixed all the problems.
  18. #43
    Oct 2006
    1,322
    Yea but my question is, Is that really the problem? I don't want to buy a 900 T body, and its not it. When i started it in front of the service adviser it still made a pop, and was running pretty bad.
  19. #44
    Oct 2006
    1,322
    Well i told you guys i'll keep you posted. It wasn't the engine....i knew that bitch was invinceable, but the tranny is done. I went to benz last night and replace the MAF sensor and converted everything back to stock. Car ran perfect like nothing happened. Well after 6 miles the car sounded like the gears was grinding bad....i turned the key off while doing 50 and dropped it in N within a flash. I looked under the car and the trans was leaking. It looked like the tail shaft seal broke. i had to go home grap my uncles flat bed tow truck and load it at 2 in the morning. As soon as i lifted the car at a angle it was pissing tranny fuild like there was no tommow. So its back at merc
  20. #45
    Feb 2007
    Boston,MA
    545
    man thank god it wasnt the engine i tell all my friends that its nearly inpossable to blow a Mercedes engine. So now noing that im still right. i can finally sleep. wow really cant blow a mercedes engine
    Mercedes
    Engineers
    Racecars
    Carfully
    Economically
    Drivability
    Even
    Safety
  21. #46
    Oct 2006
    1,322
    lmao i thought the nitrous blew it for sure. but i took out the solinod and the spring inside was stuck.
  22. #47
    Mar 2007
    1,122
    hey man, can you keep us posted on how much the repair will be, that'll be alot of help. thanks in advance
    1999 Silver C43 AMG
    Current Mods:
    Soon to come:
    ECU Tune
    Mabuhay!
  23. #48
    May 2007
    Colorado
    1,428
    so since this was under warrenty what are the total charges on fixing your ride?
    98 C43 AMG (SOLD)
  24. #49
    Oct 2006
    1,322
    $500 outta pocket
  25. #50
    Mar 2007
    1,122
    what's the 500 for? thanks in advance
    1999 Silver C43 AMG
    Current Mods:
    Soon to come:
    ECU Tune
    Mabuhay!
