Results 1 to 4 of 4
Thread: glove box bulb replacement
    Nov 2006
    220
    Gotta replace the glove box bulb. Haynes says you gotta take
    out the entire glove box to get to the bulb. Anyone done this? Looks like you
    have to pull out four rivets. Do you just pry them up and they
    come out?
    May 2006
    123
    Yes there are 4 rivets that basically just pop out. The glove box is a plastic box with a thin layer of felt on the inside. It is pretty sturdy so just pull it out and change the bulb
    Nov 2006
    220
    Do you need a special tool to pop out the rivets or can you
    do it with a screwdriver? Do you replace them by just pushing
    them back in? Don't want to rip up the felt liner in the box.
    May 2006
    123
    Yeah just use a flat head screwdriver and pop the middle part out then the whole thing pops out. To install just push it in then push down the middle button to lock it. Just make sure the screwdriver doesn't slip and scratch the felt.
