Page 1 of 7 123 ... LastLast
Results 1 to 25 of 159
Thread: DIY Adjustable rear camber arms
    Mar 2011
    242
    Save money by making your own with the help of a member on another forum
    www.speedwaymotors.com
    Parts list:
    QTY:2 91008001-STR Forged Steel-4 Bar End - Straight Shank
    $12.99 $25.98
    STYLE: Str
    QTY:2 91008002 Forged Steel 4-Bar End - Straight Shank/LH Thread
    $14.99 $29.98
    QTY:2 1750246 Jam Nut 5/8 Inch RH Raw
    $0.99 $1.98
    QTY:2 1750446 Jam Nut 5/8" LH Raw
    $0.99 $1.98
    Make sure to get 9" long links maximum, 10" is too long.
    2 91034158-9 ALUMINUM TIE ROD SLEEVE, 5/8"
    $7.99 $15.98
    LENGTH: 9
    Current Charge Summary
    Sub Total: $75.90
    Add another $10 or so for shipping. Not too shabby, just saved $200.
    Then go to the hardware store and get eight thin 7/16" inner diameter fender washers for the sides of the nylon bushings to have a nice smooth plated surface to slide on. Use some petroleum jelly on the nylon bushings in the bore that slides on the center sleeve, and on the sides against the washers, so far they work great, no squeaking or anything, and the suspension feels nice and smooth.
    You can use the stock bolts, inboard and outboard, and kept the stock safety retaining washer on the end outside of the fender washer and rod end sandwich on the outboard end, so that the new fender washer stays nice and flat.
    202brabus
    Wow!! that's really great if you can make your own camber arm. I purchase 1 from Speedybenz and I love it.
    I think it will cost you around $300+ to purchase from a member in MYMBONLINE.
    Mar 2011
    242
    1234512345
    Mar 2011
    242
    Bumpie. Come and get it!
    Mar 2011
    23
    sorry a newbie on here, but how is this different from the stock mercedes control arms?
    Quote Originally Posted by ruzhkata View Post
    If your car is lowered, then there will likely be a negative camber of the wheel. Meaning instead of your wheel being like this: l the alignment of the wheel may look more like this: /
    With an adjustable camber arm, you can extend/contact the arm to correct the camber due to the lowering.
    mazdalowandslow
    Here ya go,
    Add at the end of your order the promo code "savemore" to save 5 bucks!
    mazdalowandslow
    Nice post! Big kudos! I was trying to do this a few years back with heim joints, but I was having trouble finding the right link bar.
    Mar 2011
    242
    Save yourself $200!
    Moderator hvmercy's Avatar
    Dec 2003
    2,092
    where do we get them from 202brabus?
    Mar 2011
    23
    all this extending/contacting the arm is done when an alignment is done right? or do i do it myself?
    mazdalowandslow
    Measure eye to eye on your stock arm, recreate the measurement with the new arm. Then take your car into an alignment shop for them to put the persice angle in.
    mazdalowandslow
    Quote Originally Posted by hvmercy View Post
    Order from : http://www.speedwaymotors.com
    He listed the part numbers so you can get the right parts.
    Dec 2003
    2,092
    Duuh, not only am i blind, I'm also brain dead on this Friday afternoon. Thanks.
    Quote Originally Posted by mazdalowandslow View Post
    Fremont, CA
    1,900
    great post!!!
    988
    WOW perfect. THANK YOU , Now you should try and figure out a DIY for the fronts =D
    Mar 2011
    242
    Ill take donations lol jk
    Dec 2005
    2,213
    Excellent find!
    So with the two ends all the way threaded in, is it at stock camber?
    Mar 2011
    242
    Quote Originally Posted by OCKlasse View Post
    Excellent find!
    Yes it is.
    This is really a good find. I think I'm gonna order this for my C280. I can use the $200 for install and alignment.
    Mar 2011
    242
    You can do the install yourself, its really easy. $45 for an alignment and you saved $155 still.
    1,540
    Excellent find!
    Quote Originally Posted by 202brabus View Post
    Yes it is.
    What if people want more negative camber? Just curious.
    1997 C280 Sport
    Mar 2011
    242
    Quote Originally Posted by 97C28O View Post
    More NEG camber?... I would order the 8" rods.
    Dec 2003
    2,092
    I think I'll try this when summertime comes. I'll be replacing my tires all around and want to get more life on it this time around.
    I'll post a different thread when I'm about to do it.
    Dec 2005
    2,213
    Ordered my parts today. Can't wait to put them in...
    Thank you again!
