DIY Adjustable rear camber arms
Save money by making your own with the help of a member on another forum
www.speedwaymotors.com
Parts list:
QTY:2 91008001-STR Forged Steel-4 Bar End - Straight Shank
$12.99 $25.98
STYLE: Str
QTY:2 91008002 Forged Steel 4-Bar End - Straight Shank/LH Thread
$14.99 $29.98
QTY:2 1750246 Jam Nut 5/8 Inch RH Raw
$0.99 $1.98
QTY:2 1750446 Jam Nut 5/8" LH Raw
$0.99 $1.98
Make sure to get 9" long links maximum, 10" is too long.
2 91034158-9 ALUMINUM TIE ROD SLEEVE, 5/8"
$7.99 $15.98
LENGTH: 9
Current Charge Summary
Sub Total: $75.90
Add another $10 or so for shipping. Not too shabby, just saved $200.
Then go to the hardware store and get eight thin 7/16" inner diameter fender washers for the sides of the nylon bushings to have a nice smooth plated surface to slide on. Use some petroleum jelly on the nylon bushings in the bore that slides on the center sleeve, and on the sides against the washers, so far they work great, no squeaking or anything, and the suspension feels nice and smooth.
You can use the stock bolts, inboard and outboard, and kept the stock safety retaining washer on the end outside of the fender washer and rod end sandwich on the outboard end, so that the new fender washer stays nice and flat.
202brabus
