the battery went flat to incase that would make a difference but battery now fully charged, but problem still here, also tried re-sync the fob but still no joy
new to this site, got my first w202 . put the car in to give it some much needed tlc, car was going perfect before hand but will not start now, will light up ignition heater plugs working pump getting power etc. but just will not kick when ignition if fully on any help will be greatly apreciated
Any check engine light indicator? If so, do you know the codes.
not to sure all lights staying on the car will not turn over, don't know codes but want to know is there a simple fix before it goes on the mechanic
Try jump start it. I think the battery is old and need a new 1.
ws told that jump starting was bad for them, going to try a new battery an if that doesnt work it will have to go the mechanic
Check the park indicator. Maybe the car thinks it is gear... Put the key in run the shift selector thru all the gears and back to park. Then try again
\'94 C220
Black.
Chaos reigns within.
Reflect, repent, and reboot.
Order shall return.
just after trying there no difference, just gets to ignition then nothing happens
You should get a new battery. then you can go from there.
What year is this vehicle, mileage.
97 facelift 196k car
auto spark said it could be ignition barrel cause it is a common problem
aren't C250's diesel? you mentioned heater plugs.
does sound like a battery.
Bigger question. You had it down for some "much needed TLC." What did you do? It worked before you did it, and didn't work afterward. Just a wash/wax/interior detail? Did you do anything under the hood?
also, jump starting them is not bad for them. if I had a dime for everytime I've had to jump start my 94 C280... Anyway, no problems ever from jumpstarting or using it to jumpstart someone else. 12 years and counting.
CURRENT:
yea 2.5td, no power to the pump when the ignition is turned or to starter, nor wer they plug in on the ecu. yea just blisters on the archs etc mainly bodywork, never lifted the hood
Have you checked the OVP? I'm pretty sure the diesels still have them. It's that little box by the ECU connectors. Has a tiny glass door on top with a fuse underneath it. Turn the key to the ON position, give the OVP a good whack. If you hear the pumps and other things start to make buzzing noises and come to life, then you need a new OVP.
CURRENT:
cant see ovp relay unless its under the ecu? but was told ovp relay was discontinued on the facelift model
if that's true, that's something I had no idea about. Hmmm...
Have you checked the fuel pump relay? On gas models (pre or post facelift) it's in the trunk by the battery and fuses. Green little box relay with a fuse on it. There's a way you can yank it and use a piece of wire to connect 2 of the leads to see if it sends power to the fuel pump. Not sure which 2 leads those are...
CURRENT:
I'm a bit old school when it comes to diesels: 77 300D, 84 190D. The old diesels never had a fuel pump like the gas engines do. There were 3 things needed for the engine to run: air, compression, fuel. Man I miss that car....
Chrisy mentioned that the lights and stuff are working now the battery is charged. The fuel pump (if it exists) wouldn't stop the car from turning over. The battery is good, key fob is good, transmission is in Park or Neutral, and the engine won't even crank.
Try arming the alarm and then disarming it.
if still no good, look to the starter.
ignition lockout on the side of the tranmission a distant 3rd.
beyond here is bad thoughts only.
\'94 C220
Black.
Order shall return.
car going to auto spark, know something of cars but mercs are all new to me. will check all the above tomorrow hopefully it works though. havent heard of the ignition lockout what is this?
My apologies. I should have referred to it as a starter lockout switch instead. Basically it's what I was asking you to test by running the car thru the gears and back before.
\'94 C220
Black.
Order shall return.
wondering would the ignition module, box that sends power to pump & starter? looking for wiring diagram if anyone has it so i can look about hard wiring a switch to start, was told that mb garage was looking 4k to fix another car that done the same. so if i get mine sorted cheap may save another 202 from scrap
HAVE YOU CHECKED THE conections to starter motor and earth strap on engine no earth strap it wont start
thats what i think
