Results 1 to 7 of 7
Thread: Help on new w202 Projector headlights
    I installed these perfectly and i noticed that my right beam is aiming a bit higher. I found what i think the knobs were on the back. They're greyish with a cross or plus sign in the middle. I thought i had to put a screw driver in it to turn and adjust the beam light. Didn't work. I also tried turning the knob which was really tough. Didnt work either? I dont know how to adjust these.
    I email the company and the guy said there should be 2 knobs at the back of the headlight. But never responded after that.
    These are the headlights
    http://www.google.ca/imgres?q=have+t...w=1920&bih=950
    I finally got pictures :
    * are those silver knobs my adjustment knobs? because there the only knobs *
    *UPDATED*
    any advice please and thanks!
    Jul 2006
    Philadelphia/South Jersey
    1,547
    if you are in the US, the right(passenger side) should be aimed higher than the left. this is to avoid blinding oncoming traffic, cant help you with the adjustments on those headlights, never used them.
    Drexel Business '11
    988
    How do the headlights look installed lol ? And if they are in the same spot as the factory housing then yes those knobs should be adjusting it. But I never owned a pair of projectors.
    ^^ andf6789 I kind of figured that but its to the point where its waay up there and the left is pointing down. Difference of each beam is about half a meter?
    ^^SD202 i just updated the pics. Okay ill try again using a smaller philips screw driver.
    Oct 2016
    2
    Hi,do you still have these headlights? Where did you get them from? Thanks
    Fremont, CA
    1,900
    Quote Originally Posted by Phill67 View Post
    Just making sure you're reading this post... the last post is over 5 years ago.... FYI...
    You can find them on ebay
    Jan 2019
    3
    You can find it here :
    http://www.mercwheels.com/headlights...ts-94-00-p-927
