Results 1 to 11 of 11
Thread: Driver side door transponder
    Member
    Nov 2011
    North End
    39
    Looking all over the web for information about this and nothing. Well I'm looking for someone who knows where I can get one without going to stealership. I have a 97 c230. The driver side transponder/transmitter with the red and green light for the keyless is busted. Stealership quoted $575, for parts! That's not including labor and whatever else they decided to throw in the mix! For $575 I can get a top of the line viper alarm and still have enough left over for some stripper money. So do you know of anyone?
    Fremont, CA
    1,900
    if you have the part number try autohausaz.com or getmercedesparts.com
    Member
    Nov 2011
    North End
    39
    no i havent gotten the part number yet. maybe i shouldve when i called the dealer about the part.
    Apr 2011
    Antarctica
    551
    You know, the top-of-the-line viper alarms do have a one-mile range and a bunch of extra auxiliary functions you could hook up... pretty cool if you could get it hooked up!
    Moderator hvmercy's Avatar
    Dec 2003
    2,092
    Not worth $575 - too expensive. I lived with mine broken for a year and luckily I was able to locate a C230 with IR door handle being parted out on mbworld. Check out other forums as well. You'll never know
    they may have the part you need.
    Quote Originally Posted by Seattle_202 View Post
    Member
    Nov 2011
    North End
    39
    Quote Originally Posted by hvmercy View Post
    Hvmercy, did yours just plug n play or did u have to reprogram it/sync it to your key?
    Member
    Nov 2011
    North End
    39
    Quote Originally Posted by MikeD View Post
    At this point it's tempting to just go for the viper alarm. But I don't know how that will work with the remote start cause we have an ir chip in the key. I'm pretty sure there's a way around just need to figure it out.
    Dec 2003
    2,092
    it's plug and play.
    probably takes about 15 minutes to replace.
    Apr 2011
    Antarctica
    551
    I have a pre-facelift 202, and I'm currently doing some research on installing a python (same company as viper) alarm/remote start. I hear the facelift 202s with the smart key are tricky though. Some kind of bypasses are needed to make it work.
    Member
    Nov 2011
    North End
    39
    if you ever figure it out please let me know. i appreciate everyones help in this.
    1997 C230
    Seattle_202. I know a guy out your way who could help you out.
    Hit me up pm and I can get you details.
