Page 4 of 4 FirstFirst ... 234
Results 76 to 86 of 86
Thread: supercharger pulley upgrade
  1. #76
    Apr 2013
    Ireland
    829
    Great stuff there Piko. What sort of power does that particular Evo make and I presume he giving it full throttle?
    JJJ.
  2. #77
    Stock EVO 7 GT-A 272HP. We tried four times and the outcome was the same.
  3. #78
    Feb 2013
    biglerville pa
    783
    can I get a pickture of the intake pipe you made 80mm? and did you clamp the maf? and how dose one clamp it ..lol
  4. #79
    You eather use a piggy back to alter the signal or just solder a 4.6V diode between signal and ground.
    This Frankenstein pipe mod gained almost 0.2bar by itself:
    Air box from a CLK430 and bypass valve venting out to prevent circulation of heated air through the charger.
  5. #80
    Feb 2013
    biglerville pa
    783
    I hope you smoothed the bore on that bad mambagamba this is actually what I wanted to do as that baffle is pointless lol
    so this mod made boost and made the s.c louder I take it ?
    and where did you
    1 get the pipe
    2 the thickness of the pipe
    3 how hard was it to weld the pipe
    4 the corner section was that pushed inward?
  6. #81
    Feb 2013
    biglerville pa
    783
    oh another thing is on a 2000 c230 do I even need to clamp it ? I was reading something about it for the pre facelift cars needing it
  7. #82
    Apr 2013
    Ireland
    829
    Love it! So, what power do you reckon the C200K is producing now. An honest 250/260 BHP?
    JJJ.
  8. #83
    Feb 2013
    biglerville pa
    783
    I know I have to be at least at that point a ported and polished head really wakes these cars up, overdrive pulley @13psi ,
    and a really nice header not fleabay Click image for larger version.
  9. #84
    Yes it got a little louder. Mainly because of the open bypass.
    Got the pipe on ebay.co.uk, it's 2mm thick. A friend welded and beat it to proper shape. He's good with metal shaping. It's all smothed inside.
    I reckon it's at the 250HP mark. I'm making an even smaller charger pulley then it's on to th dyno.
  10. #85
    Apr 2013
    Ireland
    829
    Quote Originally Posted by piko View Post
    Brilliant! Let us know how you go with the Dyno.
    JJJ.
  11. #86
    Mar 2015
    9
    Beating a stock EVO put me speechless....
    That's beyond C36 realm I reckon.
    So by clamping the MAF you simply solder a 4.6v diode on the bridge of signal wire of the MAF and ground? I am not an electrician, not so clear on how to make out that part. Would be great if someone knows his stuff could be more specific? A picture or circuit diagram?
    I am going to put my header back soon since it's been repaired. Transmission is lagging sometimes, maybe I will check the fluid level and see if it's there.
    Right now fixing the car seems to be more important than making it go faster...
    Geesh... I hate hot Summer, here in Taiwan you get humid air 35' Celsius or higher at any time of the day during July and August.... Could definitely feel the car runs abit sluggish due to hot intake air
