Results 1 to 20 of 20
Thread: Rear speakers
    Oakland-Sacramento CA
    721
    Rear speakers
    Is there any way you can tighten up tye rear deck speakers? My subs rattle the shit out of them. Ive tried to just turn them as tight as i can but they are still loose
    "anyone can drive a new car, it takes a true enthusiast to breath life into an older one"
    could it be the deck itself? pack some foam under it.
    \'94 C220
    Black.
    Chaos reigns within.
    Reflect, repent, and reboot.
    Order shall return.
    Dec 2011
    6
    You should just remove them, if you get quality front and rear door speakers you wont need them. plus you'll get much more bass in the car because they will act like air ports.
    Fremont, CA
    1,900
    loctite?
    Dec 2011
    6
    What is happening is your subwoofer is pushing sir up against your rear speakers and have caused them to probably already rip which it causing the rattle.
    Feb 2013
    biglerville pa
    783
    get polly fill from wallmart like $3 for 2gal of fluff shove it in there
    then make shure your 3rd break light wont rattle
    Member
    Jul 2013
    Ft. Lauderdale, FL
    35
    Polly fill ill have to check that out I'm having similar issues just the rattle on the 3rd brake light is my main issue how would you go about fixing that? I haven't really messed with it yet I hear the plastic on the 3rd brake light can get very brittle.
    Mar 2011
    242
    Maybe applying some hot glue and shoving the 3rd lamp back in before it dries so it removes any play within the housing?
    Member
    Jul 2013
    Ft. Lauderdale, FL
    35
    Cotton balls between the front and back pieces where they connect on top did the trick for the third brake light.
    Feb 2013
    biglerville pa
    783
    see I didn't want to shove cotton inside my 3rd break light as it could catch on fire easyer I like the glue trick but if you have to change the bulb .... lol
    Quote Originally Posted by DGr1FF View Post
    Wow!!! that's something else...
    Member
    Jul 2013
    Ft. Lauderdale, FL
    35
    Quote Originally Posted by JRE320 View Post
    Thanks man! Next time instead of being a jackass though you should go take your mid-lifer FR-S for a spin instead!! What a cool car!
    LOL!!! you are a Jackass!!! cotton ball between the front. Is that the best you can say? Ha!ha!ha!!!!
    Maybe you're just a little kid that need some knowledge before you recommend.
    Member
    Jul 2013
    Ft. Lauderdale, FL
    35
    You bought a new Scion...pretty hard to justify that one. And you type like an illiterate.
    yes, I'm illiterate in typing and can't construct the proper English. Using cotton ball??? what a joke!! So what's your problem with my FR-S? Jealous.... Ha!ha!ha! you moron..
    Fremont, CA
    1,900
    Hush down gents... Consider yourselves warned.
    I'm not gonna hush down with this kind of posting. Cotton balls?? when do you ever use a cotton ball in your car? Maybe a Q-tips may work.
    Feb 2013
    biglerville pa
    783
    cotton ... I use it a lot and it works ...Click image for larger version.
ID:	2029Click image for larger version.
    Feb 2013
    biglerville pa
    783
    but I do avoid lights with it my exauhst is so loud I needed to dampen it
    May 2015
    Haddiscoe, Norfolk, GB
    8
    I am new to your club most interesting, likewise I don't think cotton around lights is a good thing. If your putting a loud system in a 202 why not change the third brake light to an LED strip high on the rear window looks good. My opinion for what it's wurth
