Results 1 to 25 of 28
Thread: springs for a jz-swapped w202
    hi people ive a 96 w202 its got power on the straights now but i want better handling out of this car.
    after some research ppl seem to have good things to say about bilstein sport shocks + H&R springs setup.
    since the car was originally a i4 c220 and it now has a heavier i6 cast block in front so what springs/shocks should i get?
    I notice there are different part numbers for c280 i6 and c220 i4 springs so i suppose they are different?
    are they interchangeable?
    how is the d2 coilover kit compared to the bilstein + H&R setup?
    i dont mind stiff ride as long as its not dangerously stiff and handles good.
    Dec 2011
    Perth, Australia
    407
    what ever you get, go for the ones made for c280/c36
    so they are direct fit ay? thanks.
    Fremont, CA
    1,900
    OP the difference is the spring rate as the I6 is heavier than the I4...
    Senior Member SpEeDy230's Avatar
    Las Vegas
    745
    post pics of the car! 1j or 2j?
    RoyalFlush202
    wichipong: thanks but c280 and c43 v8 have the same part number while c36 has a different one? i figured i should just get the one for c280/c43 correct?
    speedy230: 1jz for about 3 years and 1.5jz (2jz block with oversized cp)
    heres some
    10psi with this turbo killed the autobox 2nd gear, going for a manual conversation soon (still trying to source the manualbox)
    Jul 2011
    166
    Quote Originally Posted by evevevevev View Post
    heres some
    go c36 or c280 springs, the I6 engine is the most heavy one in the 202. the pro's will confirm if those springs will direct fit.
    Las Vegas
    745
    Nice, I like the 1.5j. Benefits of both motors! Since the 1j heads flow really well. Single turbo is awesome too. Ive always told myself that if my motor goes one day in my 202, Ill swap a VVT-I 1j in. Clean swap man
    RoyalFlush202
    North Carolina
    329
    That's a dope looking ride!
    May 2010 - July 2012: 2000 C230K, Highly modded, 142xxx miles, SOLD
    July 2012 - Present : 98 C43, 109xxx miles, H&R Springs, Eurocharged ECU Tune, AMG style pedals, aftermarket CD player.
    Quote Originally Posted by michael6129 View Post
    Thanks. will report back when I get mine fitted in a couple of weeks, i hope.
    Quote Originally Posted by SpEeDy230 View Post
    doesnt matter since both jz's has shitty heads that dont flow well (example, compared to the RB) but nothing a higher boost wont fix :P
    you will love it. it might not be as torquey as the 5.5L at low revs but the tuning potential is amazing with aftermarket supports.
    Quote Originally Posted by C43inNC View Post
    i dont quite get it here. dope good or dope bad? lol
    Jul 2006
    Philadelphia/South Jersey
    1,547
    dope=good
    Drexel Business '11
    Senior Member Yujin's Avatar
    May 2011
    MA
    613
    I just shit myself
    My W202 2000 C230 Kompressor
    Like us on Facebook!
    thanks for the kind words guys.
    booked some b8's now just waiting for them to arrive.
    also finding out the availability of the h&r at my local store.
    i might go down a different route for the gearbox. a built auto instead of manual.
    we'll see.
    Jul 2011
    166
    we'll see.
    maybe we can help on the gearbox how many hp are you running?400? box from the e19016v should do it till about 4. for extreem hp a gearbox from a straigt six diesel bmw from the nighty's those seem to be strong
    around 400whp with 13psi with a fairly rich tune. knew the gearbox was the at the limit being a stock auto.
    with better box it shuld do well over 500whp with 20+psi on pump gas.
    the problems with boxes you mentioned are they are hard to come by at where im from.
    and getting the bellhouse custom made seems like a lot of hassles and troubles.
    so im sticking with toyota boxes.
    as much as i want the tough toyota getrag 6 speed manual, i simply dont have enough fund for it right now.
    the box and clutch setup alone will cost me over 5 grands before i even attempt to begin to put them into the car.
    Jul 2011
    166
    hm, manual, or auto from a supra not available for a decent price over there? hm that sucks if it isn't
    the auto i blew is a supra auto (currently in the car) and the 6 speed i was talking about is a supra manual.
    lots of ppl built the auto and they do hold pretty well but im not sure about the local transmission shops.
    ive seen the built auto holding big power in aussies and the states tho.
    and a properly built auto will be quicker in 1/4 miles.
    however it will be a street car doing occasional drags and highway pulls.
    think manual should be better for street/strip setup since auto looses the streetability the more you wanna improve in strip.
    sourcing manual parts will be a PITA over here since ALL mercedes come with auto.
    ive never seen a manual w202 (or any merc except 190e maybe once) in my life.
    can anyone share any pics for the gear stick console and padel setup on the 202?
    Jul 2006
    1,547
    http://en.wikipedia.org/wiki/Mercede...c_transmission
    800lb ft torque capacity
    used in pretty much every mercedes from 97 on including the slr
    Drexel Business '11
    Quote Originally Posted by anf6789 View Post
    this shuld cost more than the supra 6 speed which is more simple and holds the torque as well too. :[
    problem. H&R seller has no stock for c280/c43 springs. but c36 one is available.
    why does h&R use the same spring for c280/c43 but different one for c36?
    what are the weight difference?
    after some search c36 weights 100lbs more than the c43 due to the cast iron i6 block compared to c43's aluminium v8
    so should I go with c36 since i do have a cast iron inline6 block?
    Jul 2011
    166
    yes c36 is the heaviest
    so should i go with c36 H&R instead?
    Jul 2011
    166
    depends on what kind of springs you are looking for everyone has different taste on suspension, the h&r set up for c36 should work great it's made for the heavy c36. the c43 sprins are a little weaker less stiff.
    I dont mind stiff ride as long as its not stupid.
    seems like c36 one should do the job better since the jz is really a heavy bastard.
    Dec 2011
    Perth, Australia
    407
    jz is lighter than the m104...
