Results 1 to 13 of 13
Thread: fuel injectors what fits
Hybrid View
    Feb 2013
    biglerville pa
    783
    well exactly that what all fuel injectors will fit in our motors without much mods and what size injectors do our cars have
    Feb 2013
    biglerville pa
    783
    :bump: ?
    May 2013
    Bulgaria
    203
    M111 2.0K - Stock -
    Siemens 0000788123
    280 cc/min @ 3 bar
    311 cc/min @ 3.7 bar
    323 cc/min @ 4.0 bar
    Feb 2013
    biglerville pa
    783
    these will fit the 2.3 ?
    Dec 2006
    Norcal
    2,864
    Bosche style off a lot of domestics fit also.
    May 2013
    Bulgaria
    203
    They are the same on the 2.3
    Feb 2013
    biglerville pa
    783
    anything that's about 400cc? to 6? I mean the cc from the 4g63 eclipse motor are 450cc for a set is 460$
    Aug 2012
    18
    injector from 4g63 won't fit as the top o-ring is smaller in diameter and also they are low-impedance.
    try to find injector that fit bmw and mustange they should work
    Feb 2013
    biglerville pa
    783
    yzn what if I ran the fuel rail off of a 4g63 ? or am I thinking of the wrong end of the injector lol and thanks rumB
    Feb 2013
    biglerville pa
    783
    krumb now those are low independence right ? what els would I need as far as the high low part
    Aug 2012
    18
    4g63 fuel rail won't work as the spacing between injectors are different compared to the m111, i have machined the 4g63 injectors to fit the original o-ring of the m111 injectors
    Aug 2012
    SoCalif
    1,011
    I've been researching a lot of performance options for thee car lately. I know this thread is a few years old but here is some good info I've come across on flow rates of the stock C220 AND C230 injectors-(They all have the same part number from what I've read)
    The stock MB injector is a 21.5 lb injector. It has a flow rate of 220cc. (gray body/ green tip) {CLAIM}
    Bosch injectors part# 280-155-209 is a 18.8 lb /199 cc 14.25 ohms {Hard Data}
    These are all injectors used in the C220, C230 (Not C230K) and C280 motors
    Bostech injector part #MP5091 is 23.5 lb / 240 cc {CLAIM}
    Bostech injector part #MP5007 is 21.5 lb / 220 cc (same as OEM MB injector- I actually think this may be the OEM ones used by MB because they are the same color: Gray/green tip) {CLAIM}
    Bosch AMG injectors C36 use the 280-155-757 (I've seen claims in adds of 255cc) Data off of 2 different injector cleaning sites (19lbs/ 199.7cc) 14.5 ohms {Hard Data}
    http://www.injectorcleaning.co.uk/flow.htm
    http://users.erols.com/srweiss/tableifc.htm
