Results 1 to 9 of 9
Thread: No reverse light fix?
    I've checked the fuse, and replaced the bulbs but still no light. I have inspection in 7 days so I will definitely need it fixed. Any ideas?
    Jan 2004
    San Francisco
    786
    What year is the car? On the 94-95 cars withe biodegradable harnesses the reverse light/neutral safety switch harness can degrade. In my case I lost the reverse lights.
    1994 C280
    1996 C36
    2005 C55
    2013 Volvo XC60 R-Design
    1999 Porsche 911
    3,219
    If you have one check the stop lamp switch on the brake pedal is working as should, should be mounted above the pedal.
    These fail all the time on the updated models however these are a slightly different style switch.
    >>99 S202 RED 250TD Daily.
    >>89 2.6 RED w/16vkit. POS
    Feb 2012
    17
    I have a 97 C280 and my reverse lights are inoperable as well. Any thoughts?
    3,219
    Sorry disregard my input, thought it was stop lamps
    reverse lights are taken from the gate shifter, could be a failed switch. Or as mentioned a fail harness but imagine this blows fuses??
    Feb 2012
    17
    Quote Originally Posted by mbsickness View Post
    Feb 2012
    17
    Problem solved lol. Turns out the shifter was dodgy. Got a replacement unit from the wreckers which solved the problem. However, the new shifter has a certain spot in the reverse channel where it wont trigger the lights. No biggie; looking into tearing up the old one to see what needs to be fixed. Was originally quoted 600 for the job including a 300 part; this was from a specialist. Couldn't justify paying that much lol. The wrecked shifter was only 150 plus tax and a new bushings were only 4 bucks a piece plus tax.
    3,219
    Well done man!
