Results 1 to 10 of 10
Thread: HELP with headunit and bose system!!
    Member
    Jan 2015
    new york, New York
    51
    Question HELP with headunit and bose system!!
    ok got everything i need
    metra 1784 VW
    pac soem4
    aftermarket headunit
    i connected them using tape before i solder to get a better understanding but the wires arnt actually connected yet. Can someone tell me if this is correct here is the link to where i got the info.
    http://www.club202.com/forums/showth...ht=bose+system
    i connected the wires referencing 97c280. i put the aftermarket headunit on the input side of the pac and the metra on the outside. again wasnt sure about if this was correct.
    "Ok, I think I've got a solution but not entirely sure (it makes sense in my head)"
    METRA HARNESS>AFTERMARKET HU HARNESS
    red>yellow
    yellow>red
    black>black
    orange/white>orange/white
    blue/white>blue/white
    METRA HARNESS>PAC LOC
    white>white
    white/black>white/black
    green>green
    green/black>green/black
    grey>grey
    grey/black>grey/black
    purple>purple
    purple/black>purple/black
    AFTERMARKET HU>PAC LOC
    white>white
    green>green
    grey>grey
    purple>purple
    ***UNUSED WIRES***
    PAC LOC: BLUE, YELLOW, BLACK(x3)
    AFTERMARKET HU HARNESS: Light Blue, BlueClick image for larger version.
    In Charge
    Left Lane
    4,533
    That sounds about right, but would need to pull out my system to confirm. I used a wiring diagram that was posted somewhere on the site.
    edit: I tried searching for the wiring diagram. Unfortunately, when we changed over servers alot of the pictures and proper links were scrambled. IIRC, I have a hard copy of the diagram at home. If you can hold out a day or so, I can look for it and post up a copy.
    Den
    1998 C43
    1994 C280 (Retired)
    Member
    Jan 2015
    new york, New York
    51
    Quote Originally Posted by Denlasoul View Post
    Den
    that would be great, can you post asap. thankyou. i was going to try and install today but since you said you can confirm ill wait
    May 2003
    4,927
    hopefully you can find the constant power cause its switched and i can't remember which wires, its been so long. sorry I'm not much help just a heads up from what i remember when i installed my head unit 9years ago
    May 2003
    4,927
    Member
    Jan 2015
    new york, New York
    51
    Quote Originally Posted by jnolte View Post
    The hardest thing is wiring the PAC which I still have not got yet:
    Member
    Jan 2015
    new york, New York
    51
    Did you ever find that wiring diagram?
    In Charge
    Left Lane
    4,533
    No I did not. I will have to pull out my hu to get the wiring schematics.
    1998 C43
    1994 C280 (Retired)
    Member
    Jan 2015
    new york, New York
    51
    Its ok. I finally got it after four hours of playing around with the wiring. Couldn't figure it out. Turns out it was just the blue wire that wasn't connected on the PAC to the wiring harness. Thanks anyway!
    Senior Member Logic's Avatar
    May 2007
    Colorado
    1,428
    Quote Originally Posted by adge_dre View Post
    did you try installing the radio without the pac piece ? if so did the volume get loud quick and was there popping when it was turned on or pressing of buttons ? in some cases the soem4 piece is to allow adjustment if the radio gets loud to fast or popping noises if they are there . if not the pac piece is not needed in some cases , i also seem some harnesses that have the RCA ends on instead of wiring which allow low level into the harness instead of high level .
    98 C43 AMG (SOLD)
