Idler arm relocation?
Exactly what it says how hard would it be to do, getting a header off of Mike and I would like to be a little more informed on what happens when you move it,
I'm probably just looking to swing it to clear at the same angle or bend the header witch I don't wana do if I can figure this out I'm going to relay my finding to dyno comp for our cars
Build the exhaust around it. Impossible to mimic the geometry if to move the pivot or length.
I'm buying the dyno comp header from Mike he said it hits the bolt on the idler arm so I'll have to really see what I can do when I tear into it
nvm about it I see what you mean vetruck ive seen some guys do some but I see it would be very time consuming so I shortened the header up
