Results 1 to 15 of 15
Thread: Spring Pad Sizing
    Member
    Jul 2013
    Ft. Lauderdale, FL
    35
    Spring Pad Sizing
    So I am in the process of ordering my suspension setup already ordered eibach springs and yellow koni shocks. The last part I need to buy is the spring pads. I went out today to see which pads are currently in the car, and the back and fronts are both the "3 dot" or level 3 pads. I want my wheel gap to match and currently my front wheel gap is much larger than my back. This could be because springs were replaced, though I doubt that, and the other ones settled more. I'm thinking of going level 1 "5mm" in the fronts and keep the 3 but order new ones in the back. Anyone have any opinion on this? Is my thinking/judgement correct? Anything is appreciated, thanks guys!
    Apr 2006
    Europe
    752
    i have #1 in front and #4 rear for a raked look
    i'm using koni yellows and vogtland springs.
    my c43 looks very sweet with this setup
    Member
    Jul 2013
    Ft. Lauderdale, FL
    35
    With that setup do you have any rear wheel gap? And is there any rubbing in the front?
    Apr 2006
    Europe
    752
    i can barely fit my index finger in the wheel gaps.
    i have no rubbing issues
    Aug 2012
    SoCalif
    1,011
    Quote Originally Posted by DGr1FF View Post
    I would highly recommend you install the new springs and shocks with just using the original spring pads you currently have and see where it sits. There are many variants that can change ride heights between your car and someone else's with what appears to be the same setup. Wheel widths (leverage from suspension pivot changes), shock gas charge differences, vehicle weight options, suspension bushing conditions- are a few examples of these variances.
    Once installed and test drive a few days, you will be able to then easily measure what needs to go where.
    Keep in mind that when you measure wheel gap, a spring pad change will be twice the distance the pad thickness is since the pad/spring sit at about 50% leverage point from pivot to wheel centerline. ( in other words, a 7mm change in pad height can mean more like a 14mm change in actual ride height.)
    Member
    Jul 2013
    Ft. Lauderdale, FL
    35
    Does anyone know if these are the correct part numbers for spring pads for the W202?
    FRONT SPRING PADS
    210 321 01 84 5mm
    210 321 02 84 9 mm
    210 321 03 84 13 mm
    210 321 04 84 17 mm
    210 321 05 84 21 mm
    REAR SPRING PADS
    210 325 01 84 5 mm
    210 325 02 84 9 mm
    210 325 03 84 13 mm
    210 325 04 84 17 mm
    Member
    Jul 2013
    Ft. Lauderdale, FL
    35
    FRONT SPRING PADS
    210 321 01 84 5mm
    210 321 02 84 9 mm
    210 321 03 84 13 mm
    210 321 04 84 17 mm
    210 321 05 84 21 mm
    REAR SPRING PADS
    210 325 01 84 5 mm
    210 325 02 84 9 mm
    210 325 03 84 13 mm
    210 325 04 84 17 mm
    Aug 2012
    SoCalif
    1,011
    The part munber you have are for all W202's from mid96-00 year cars.
    For W202 94-mid 96
    Front(W201 part number) :
    201 321 09 84 pad#1 8 mm
    201 321 10 84 pad#2 13 mm
    201 321 11 84 pad#3 18 mm
    201 321 12 84 pad#4 23 mm
    Rear(W201 part number) :
    201 325 09 44 pad#1 8 mm
    201 325 10 44 pad#2 13 mm
    201 325 11 44 pad#3 18 mm
    Member
    Jul 2013
    Ft. Lauderdale, FL
    35
    I drive a 2000 C230. I am looking for the 210 321 02 84 9 mm for the fronts. When I google the part number, the websites that come up say that it does not fit my vehicle. Says that part # fits 96-99 E300's.
    Senior Member Logic's Avatar
    May 2007
    Colorado
    1,428
    mine was the same ....good look for the w202
    98 C43 AMG (SOLD)
    Aug 2012
    SoCalif
    1,011
    They are correct. They are the proper helix type spring pad to mesh with the later style helix W202 springs.
    Member
    Jul 2013
    Ft. Lauderdale, FL
    35
    So I got the suspension job done. Unfortunately the 210 325 03 84 13 mm rear spring pad and the 210 321 02 84 9 mm front spring pads would not fit over the springs (Eibach Pro Kit) so I'm guessing that's an incorrect part #. Was only $40 extra so no big deal. Here is a "before" (few years back) and after of the wheel gaps. After looking under the car (friend mechanic) he showed me that I am going to need new control arms and ball joints. Anyone know of a good (cheaper) place to start looking? Thanks.
ID:	2963Click image for larger version.
    Aug 2012
    SoCalif
    1,011
    Can you share what part number Eibach kit you used? Reason being is the spring pad reference #'s I posted are archives from both this site AND Pelican Parts forums. If this info is wrong I would like to correct it. Any help with parts problems and non compatibility would be helpful for future member reference. Thank you, Dean
    Member
    Jul 2013
    Ft. Lauderdale, FL
    35
    Eibach Pro-Kit Lowering Springs
    Eibach Springs Pro Kit
    2000 Mercedes-Benz C-Class
    (C230K, without S/Lev, chassis W202)
    Part #: 2545.140
    Wasn't thrilled that they didn't fit as my front wheel gap is 2 finger and my back wheel gap is 1. Ride height way better but when you spend upwards of $1k you want the height how you want it. I'd love some opinions.
    Apr 2013
    Ireland
    829
    2545-140 are designed for: C230 K, C240, C280, C250 D & C250 TD. All of these versions have different curb weights and curb weight will vary again depending on what options are fitted. So, to get the perfect ride height you'll more than likely need to change the spring pads.
    JJJ.
