They are intended for cars carrying heavy loads. Other then that they are just like a conventional shock but more money. Are you planning on driving with 500+ extra pounds in the car then what the car is designed for?
What's people's opinions on air shocks
Was thinking on doing a air shocks setup if there is any benefits for it over conventional shocks/ struts
No actually, but I'm glad you replied as you know alot on suspension
My father's old t.a had air shocks on it so it ran past my mind I'm not looking for super duty shocks but something I can adjust to please my tastes
Are they all that heavy duty ? Depending on the air psi will it make it stiffer or looser ?
Kinda like say more air I make them stiffer and lower air for comfort
THey are basically for load "assist". You have not mentioned this but to clarify in case this is your intent- they should not be used in place of your coil springs. What happens if you use them properly as intended to assist load is they make the suspension lift and become very losfty. You will change the geometry of the suspension by changing ride heights. THey are to be inflated with extra load ONLy to maintain a proper ride height.
Sorry I took so long to respond, I have been very busy lately on not on here.
I wouldn't be replacing the coils for them I'd do a actual air bag setup with normal shocks if that were the case
But I'm gna retain the spring / strut combo for now
My intent was wondering about spring coil / air shocks setup
