Results 1 to 13 of 13
Thread: Were i can get LCA poly bushings?
    Jan 2016
    8
    As the tittle said please can someone tell me or share some link? I really thank you guys in advance.
    Jan 2016
    8
    Nevermind i find em thanks anyways!
    Dec 2015
    6
    Benz1515 Care to share the link?
    Aug 2012
    SoCalif
    1,011
    If you are lowering the car any substantial amount, you guys may want to consider KMAC eccentric bushings for the front lower control arms/ They correct the negative front camber when the geometry of the suspension arms become more parallel to the ground and force the bottom of the wheel outward.
    http://www.k-mac.com/product/mercede...aster-adj-kit/
    Apr 2013
    Ireland
    829
    Hey Vetruck, a question for you. When would you suggest the need for fitting the KMac bushings, anything over 1.5 inch/37mm drop?
    JJJ.
    Jan 2016
    8
    Clever part here, will have it in mind but i dont think i will lower my car to ridiculous propotions, i just want to lower it enough to look good and function great on 18x8.5 and 18x9.5 on a set of KYB shocks.
    Jan 2016
    8
    Good question here.
    Aug 2012
    SoCalif
    1,011
    Sorry guys, Had family issues and was away for a few days.
    I ran the calculations on the car when I first bought it 4 years ago and if I recall it needed the corrections at about 1.5" lower than OEM. Once at about 2" drop the car was static -1.2* camber up front and went to about -1.8* dynamic in suspension travel over bumps to about 2.5" drop equivilent (1 inch suspension travel from 1.5" static drop) The cars should not run more then about -0.4* front static camber
    Aug 2012
    SoCalif
    1,011
    Jan 2016
    8
    Sounds good, but is there a camber plate for the top of the strut/shocks available for these cars instead of that bushing?
    Because honestly i think is a better option and easier to adjust than the eccentric bushing!
    Senior Member Chisel86's Avatar
    Aug 2015
    Houston, TX
    127
    Quote Originally Posted by Benz1515 View Post
    No because these cars do not have a strut, they are upper and lower control arms with a regular shock and spring separate from each other, not a coil-over.
    KOMPRESSED
    Jan 2016
    8
    Quote Originally Posted by Chisel86 View Post
    Yeah how stupid i am lol, i just toughth it was like my 300CE
