Help me please!!! (Windows)
I roll my windows down turned off my car went inside the store came back out and none of my windows roll back up not even with sunroof all windos stuck open what do i do!! Help
Domt know where it is lol
fuse box under the hood drivers side if i believe closest to the windsheild
hold the lock button aimed at the drivers side handle you will see a small box just press lock and hold if they go up yay quick fix
and the fuses goto multiple things so might as well check them all while your in there
lastly did you spill anything on the center consol ? is so that is a 500$part from dealer ... even used very pricy but
lastly are you hitting the second switch on the switches? there is manual and auto up and down you may have to reset it
