Results 1 to 7 of 7
Thread: 17x10 ET 25 - Will they fit?
    Jan 2016
    11
    As above, about to buy a set of wheels
    Front: 17x8.5 ET 25 (I think!)
    Rear: 17x10 ET 25
    Not sure on tyre sizes but wheels are cheap enough I don't mind splashing out for new rubber
    Any ideas if these will fit? Or if they will require much modification?
    Aug 2012
    SoCalif
    1,011
    I have 9.5" wheels on the back of mine and they are tight. I would say no. With a 245-35-18 tire I was fine, but with a 255-35-18 tire I rubbed with 9.5" wide wheels
    Fremont, CA
    1,900
    it will require a bit modification/ stretched tires to pull it off
    Jan 2016
    11
    Ok so quick update! Turns out the guy was wrong with the offsets lol the actual sizes are as follows:
    Front: 17x8.5 ET20 with 205/45/17 tyres
    Rear: 17x10 ET10 with 215/45/17 tyres
    Dec 2011
    Perth, Australia
    407
    how the fuck do yo get 215's on 10 inch rims?
    And why?
    Aug 2012
    SoCalif
    1,011
    Quote Originally Posted by Dearlove View Post
    And why?
    It is the reason I stopped responding because the fact it is not safe. I realize each person has a right to like what the want, but when safety comes into play I will not condone any tech advice that can and potentially will be harmfull to a person or others on the road.
    Disagree with my advice (or Dearloves advice for that matter which is pretty much the same response) then all you have to do is look at the tire manufacturers specs for that tire and see it is not designed for a rim that wide.
    Aug 2012
    SoCalif
    1,011
    No further discussion needed here. These wheels and tire combo will NOT fit the car properly. End of discussion.
