I've had problems starting car once at normal operating temperature was told it was the crank shaft position sensor my first question would be what is the torque needed on the torx screw. Secondly must battery be disconnected when changing the cps. Also there is pipe coming out after the dip stick that is missing what I think is a breather pipe where does this pipe supposed to connect to. I got airleaking through this pipe. In my luggage compartment if u lift up mat over spare there is another plastic cover protecting electronics I have a loose plug that I can't seem to find where it goes maybe someone has a diagram for me. All help would be appreciated.thanks
