Results 1 to 14 of 14
Thread: cheap w202 diagnostic scan tool?
Hybrid View
    Dec 2017
    14
    Hello all, I'm looking for a w202 scan tool to read/clear diagnostic codes. I already have the iCarsoft i980, it works on my w203 but not a w202. Any scan tools that are on the cheap that do both w202 and w203?
    Dec 2017
    14
    Anyone?
    May 2013
    Durban South Africa
    264
    Lightbulb
    Quote Originally Posted by W/202 View Post
    Anyone?
    carsoft 7.4 Chinese clone works well with the 38 pin
    Dec 2017
    14
    Quote Originally Posted by Abbaso View Post
    Thanks. I saw that one too. Just order Autel md802 elite and a 38pin adapter. Should be able to do both w202 and w203 models now
    Nov 2019
    Philippines
    7
    Sorry to revive an old thread but may I ask how your Autel md802 elite is doing with your w202? I was told that iCarsoft MV V1.0 works for the W202. I wonder if anyone here has any review on this tool with the w202, as I am also in the market for a diagnostic tool
    Dec 2017
    14
    Quote Originally Posted by jakewise View Post
    It scans all systems, and can read live data. I did not use the live data yet, bit this tool basically does everything but rewrite to the ecu. Any specifics you would like to know?
    I searched "autel md802 elite all systems mercedes w202" and a few reviews popped up. Check them out!
    I have an old school Actron. Works ok I guess.
    Member
    Dec 2005
    Texas
    46
    I have an Autel Maxiscan MS300 that works just fine to clear DTC codes but I need to clear transmissions codes on my 98 C280 and it is not capable of that so I bought a Autel MD 802. The MD 802 has the capability to clear the code but you can not use just any cheapo ODBII to 38 pin adapter, which I have found out by researching different forums. It needs a specific Autel adapter. From what I have read it needs the Benz-38/DB15 Femaled for Autel DS708 that cable on amazon is $112.99. I haven't purchased that cable yet but I have different cable on order right now, the BENZ-38 Adapter for Autel MaxiSys MS905 MS908 MS906 $ 29.99 on amazon, to see if it will work and if so I will post it here for you. I had tried one of the generic adapters and all that I got was a link error.
    Here are a couple of links to some info that I found about a 38 pin adapter for the MD802:
    https://pro.autel.com/autelsupport/M...typeName=MD802
    https://www.amazon.com/gp/customer-r...d=OES8UFIXMO1F
    Dec 2017
    14
    @ezbrown I pretty much came up with the same info as you. I ordered this cable, hasn't arrived yet
    http://m.autelsale.com/wholesale/ben...5-femaled.html
    I saw the BENZ-38 Adapter for Autel MaxiSys MS905 MS908 MS906 $ 29.99 on amazon too, but I passed on that figuring it wouldn't work. Hopefully it works, you will have saved yourself quite a few bucks
    Member
    Dec 2005
    Texas
    46
    I got the cable today and was able to clear my transmission codes. I used this one , BENZ-38 Adapter for Autel MaxiSys MS905 MS908 MS906 SCANNER https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 and it worked just fine. Cost was $29.99
    Nov 2019
    Philippines
    7
    Hi,, do you have the 38 pin connector like what I have? May I ask what you mean by live data? I need to know if this tool is enough to do all DIY works for our w202 and if it comes with a 38 pin connector already as I heard many people say that not all adaptors adapt to a diagnostic tool well, just to lessen possible cost instead of bringing it to the dealership. How much did you buy it then? I asked because it was suggested to buy the iCarsoft MB V1.0 which sells with a 38 pin connector for 169 pounds. I will also look into the thread you suggested, thanks
    Dec 2017
    14
    Sorry for the delayed response, have been away for a while.
    I don't have or use the 38pin connector, I have a US model where everything is done through the ODBII port.
    Nov 2019
    Philippines
    7
