Originally posted by C280 JR
there is a fat hose that connects right to it, can i take it out there?
Elvir
No.
Once you start the car with it disconnected, THEN you have pinpointed the problem. If it is the problem, then it is most likely the bearing gone bad. In which case you will have to replace the entire pump.
It warms up the cat on cold start.
