Results 1 to 8 of 8
Thread: Exclusive look at my Heat shield
    1,719
    Took me about 5 hours of fabricating and only cost $15 for the sheet of metal and other materials.
    Upcoming mod
    I wish.
    Till next time
    me and j we're just talking about heatshields. more details man.
    1,719
    It was really to hard to make all i used was air cutoff tool and some metal files.
    a)did some measuring first.
    b) made a few model ones first out of poster board. This is the hardest step, i just add some more pieces of poster board with satples and reshaped it. Its just trial and erorr.
    c) layed it out on the metal sheet( 20 gauge stainless steel) traced the model.
    d) Start cutting, this part probably took the longest, b/c my air compressor didn't produce air fast enough, so i had to wait for the pressure to go back up.
    e)folded the creases this was tricky, i had to grind the line down a little bit and then clamped it down then folded it.
    f) test fitted the piece and filed all the sharp corners off. then did minor cutting and fitting to make it fit right.
    g)measured the mounting backrets, cut them out then welded it in place.
    i cut the hole for the pipe last just to make sure i had everything right but if i re-made i would've cutted out when i was cutting out the whole thing.
    I still have to wrap the intake and the out side with heat wrap and shape a little scoupe from the fog light hole so that the air can get to the filter easier.
    i dont need a lid b/c i measured it perfectly so that it touched the hood when its closed.
    thats pretty much it, if you need help just holla.
    Till next time
    Jason
    sweet intake dude!!! I think you should have made it a bit taller to make it more effecient!!!
    how does it sound?
    ps. where is your engine undershield and get a replacment bracket for your coolant overflow pipe!
    this gives me a chance to pimp mine:
    1,719
    how does it sound?
    Its pretty tall when i open up the hood there an imprint of it in that damper thing.
    Sound nice, bit kinda loud after 3k especially when i gun it, but works really good, feel a big improvement, a lot less lag even on hot days. At night its way good. I still need to put some insulator tape on the outside to really make it cooler on the inside.
    The engine undershiled are long gone, when i spun out last year. Haven't felt the need to buy it yet, DO I REALLY NEED THEM?? Theres a whole mess of little stuff i need to buy just too damn lazy.
    714,
    Try to add some more sheet metal to your heat sheild so that you can completely seal it up, except for the intake pipe coming from the right fog light area. And make sure the top seals against the hood tight.
    2ndly I would find a bigger filter for your system. I am sure your current filter is somewhat restrictive to the airflow.
    But the real key is too pull the air off a high pressure zone at the front of the car and then make sure all your piping and airbox are sealed up and airtight.
    What you have now is, likeyou said a big improvement over the stock setup, but if you do the above it will really kick some airflow butt.
    1,719
    cool thanks for the suggestions jeff, i am goin to start playing around with it more next week. i'll keep you updated.
    Jun 2003
    397
    Where did you get the Filter
    and intake pipe? Very cool, noticed any difference in performance?
    Benzmeister
    1999 C280
