Re: Re: 1996 c280 sport
Originally posted by crsh2
202rules how's your car?
Is it Fix? [/B]
I just nabbed an OBD II scanner from checkers (they'll let me keep it for a couple of days) and I swapped the coil ends of cylinders 6 and 2. But I couldn't get the missfire when I turned the car on, the thing is this problem will happen every day, but not necessarily every time I start the car.
So I'm gonna check the codes tomorrow when it starts doing it and see what cylinder missfires, if still 6, I'll swap the coils, if it's still 6, I'll check the spark plugs, if still missfires, then it's probably my wiring harness
