Results 1 to 4 of 4
Thread: what oil for Diff????
    1,719
    Hey i want to change my differantial oil, and i was wondering what kinda oil I should use?? redline, factory etc . . .
    thanks for you suggestions.
    I have been using Redline Lt. Shock Proof gear oil and it is performing very well. It is a lighter viscosity than what MB calls for but then it's a very good oil.
    1,719
    Where can i get that stuff at jeff online??
    Anybody else on what they used for Differential oil??
    Should i just go with the stock stuff, since MBis uses good quality fluids anyways.
    Jason
    I would guess the stock stuff is very good also.
    I just try to lower the frictional losses of the drivetrain by using these High performance oils that are lighter in weight.
    And I do think it makes a small difference.
    Besides, when the rear diff blows it will give me the chance to put a 3.46:1 rear ring and pinon in.
