Results 1 to 25 of 46
Thread: DIY maintenance work
    639
    Smile DIY maintenance work
    Dear Guys,
    I'm wondering to do myself next maintenance service at 100000Km of my kompressor 1998cc W202.
    I've already searched and informed how to perform oil change (special tool,...) but please still need some clarification:
    1) Do I need to lift the car to access to the drainage nut and undercar plastic cover? May be a portable jack to put in front (where to avoid damage) of car?
    2) Do the stealership provide new washer for the oil nut?
    3) Do I really need a calibrated wrench for the oil nut and oil filter cap, because I'll be forced to purchase one with also the special oil remover tool?
    Coolant (never changed before!)
    1)same as above point 1 There is only a drainage in the radiator of there is also one in the engine block?
    2)same of above point 2
    3)same of above point 3
    Spark plug, mine was replaced at 67000 Km, do I need to change now? Car go really well.
    I can't find a maintenance manual because mine is a particular engine: 1998cc with kompressor with similar power and torque of C230K. Does someone suggest me where to provide one?
    I'll appreciate again all your information, I confirm that we are so lucky because we have W202 and this is really the nicest Mercedes forum.
    Hi
    Marco
    lift the car, remove the lower cover, the bolt will be facing the left wheel ( well it does on my c220, donno about yours).
    if u get an oil filter, it comes with the washer, especially if u're buying it from oriely (wix brand). 8-9 bucks.
    u can get a oil filter cap tool from autozone. u know where the oil filter cap is right?
    the drain plug bolt is a # 13. while leanring from my mistakes, learned to tighten it just till it stops moving. no yanking!
    oh and as for plugs, i change mine every 30k miles just to keep the fuel and preformance at a good level.
    i go with Bosch plat plus 4. but hopefully some c230K owner will verify if you could use the same.
    good luck
    95 C220 Moonstone/Gray mb-tex
    MODS
    - Replica Avantgarde Grill
    - Flat hood Emblem
    - Plat +4 plugs
    - XM Radio
    - pioneer 12\" DVC Sub
    - Boss amp
    - H&R Springs
    - Bilstein sports up front
    - 17\" MOMO\'s
    639
    Originally posted by fastmayte
    lift the car, question is if is better a workshop jack to put in front of the car? remove the lower cover, the bolt will be facing the left wheel ( well it does on my c220, donno about yours).
    if u get an oil filter, it comes with the washer, especially if u're buying it from oriely (wix brand). 8-9 bucks.I'll buy to the stealership, probably they provide the washer for the oil nut! At least I hope.
    u can get a oil filter cap tool from autozone. u know where the oil filter cap is right?I can see it. Do I have to avoid over- tightening?
    the drain plug bolt is a # 13. while leanring from my mistakes, learned to tighten it just till it stops moving. no yanking! Ok so calibrated wrench is not necessary
    oh and as for plugs, i change mine every 30k miles just to keep the fuel and preformance at a good level.so with 30000Km I'm still OK
    good luck
    Thanks a lot for the info. If you have also info on coolant change and workshop manual it'll be wonderfull.
    Thanks again
    well what i do is i bought the walmart ramps. they are like 10 bucks or so and make oil changes alot easier instead of jacking up both sides.
    last time i bought a oil filter from the dealer, it was extra for the washer but sold togather, as in taped up on to the box. also came with teh oil filter cap gasket. the wix one comes with the washer and oil filter cap gasket. but the dealer filter seems to run the car slightly cooler. same price for the filters....
    yea, as calling my dealer alot for torque specs for various bolts and stuff and getting the same answer every time " snug " . just stop tightening when it stops moving with a slight nudge. the rubber gasket will keep it from leaking anyhow.
    yea, #13 works for me just fine. make sure u know your tighty/loosy.....
    30k miles is like what? 50k km's? or somethin like that. u can change them if u want, it's a easy job and fairly cheap (6 bucks a plug). but notihng really serious. i just change them on every car i have cuz it's a cheap job.
    oh, donno anything about the coolant thing. sorri
    MODS
    - Flat hood Emblem
    - Plat +4 plugs
    - XM Radio
    - Boss amp
    - H&R Springs
    - 17\" MOMO\'s
    713
    i dun think they have wal-mart in italy do they? :P
    Autostart Autostarter
    Progress Rear Sway Bar
    USDM Bodykit
    USDM Foglights
    1997 AMG C36 (RIP Thank God)
    OEM Bosche Clear Corners
    OEM AdvanteGarde Grill
    Bilstein Sport Shocks
    Eibach Springs
    Zender rear lip spoiler
    W210 mirrors
    oh damn. didn't see the italy part. hummm. can't go on with out walmart
    MODS
    - Flat hood Emblem
    - Plat +4 plugs
    - XM Radio
    - Boss amp
    - H&R Springs
    - 17\" MOMO\'s
    639
    100% correct
    So, I really appreciate your kind help fastmayte, thanks a lot.
    About spark plug, mine have ab.30000Km (not miles), should be ab.20000miles so, they are not to change already.
    Wal-mart does exist a picture so I can look for something similar here in Italy?
    About coolant change, if does exist any info it'll we wonderfull.
    Besides are there other suggested maintenance job at 100000Km (ab.60000 miles)? MAS, just changed, differential and gearbox changed previously, brake oil (every 2 year) changed last year.
    I'm planning only the engine oil and coolant job, plus the air filter.
    Really nice to work on own car.
    hey, no probs dude. payin someone else to do maintainance is just a waste to me, haha. it's simple stuff
    dw about the plugs. u got really low miles. i tihnk the only thing u should be really just doing is oil changes. and the air filter. if u start seeing bad mpg's or engine idlin or driving weird, replace the plugs then.
    actually if u go to an auto parts store, they should have those drive on ramps.
    yea just check the book for maintainnace needs. u can prolly do most of em in the book.
    lol, thankx. i'm still spending alot to get the car into 100% running condition. aa well
    MODS
    - Flat hood Emblem
    - Plat +4 plugs
    - XM Radio
    - Boss amp
    - H&R Springs
    - 17\" MOMO\'s
    639
    Dear fastmayte,
    nice to see your reply. As I'm was wondering oil/filters change are the only necessary work to do. May be also the internal clima air filter. Plus the coolant that is not changed probably since the factory and I'm looking for necessary DIY information.
    As soon, hoping very soon, I'll install Koni and H&R I'll check also at the shop the brake pads condition.
    Hoping to find here this really usefull car-ramps, really attractive device for all of us
    Hi
    639
    As usually to avoid new tread I resume other (my in this case) new one.
    Yesterday I was under the car, not lifted , attempting to un-screw on the right side the engine block coolant plug, it's really difficoult to operate with tool in that position (mine is a 4-cil.).
    Please how do you suggest me to operate. My dad, because warried, did not permit me to lift the car because we had not any support to put as safety instead of the car jack, but a part this there is really small room to insert and operate teh plug nut.
    Please do you have any suggestion help for me.
    Hi
    make some simple ramps to drive the car on to
    Talking
    jnolte when u say make some simple ramps lets hope he dont go making them out of wood yeh, and he means simple as if ur a MiG welding specialist or something, another thing u get is those things you know u can put ur car on each side they are triangular metal stools i dont know what theyre called i got two though, jack one side of the car up and put one under
    jack the other side of the car up put one under and job done and u know what the car sits nicely on those two rubber things on each side of the car.......probably cheaper to pick up than ramps too, i got two which hold up the vans aswell strong ones and second hand for £5 cant beat that hey
    639
    Thanks friends.
    Wood ramps are what I was looking, wondering also to the triangolar metal tools but I'm worried if the support on the car side will be enough firm (the base seem me quite small!)
    My question is also related to the small room to operate a tool (an open ended key I belive) in that small space, have someone ever attempted?
    y not just use jack stands? i use that now since i lowered the car. get a floor jack to lift the car, much easier and safer than factory jack.
    MODS
    - Flat hood Emblem
    - Plat +4 plugs
    - XM Radio
    - Boss amp
    - H&R Springs
    - 17\" MOMO\'s
    Is there any way you can utilize a curb to lift on side up? You know like raise the car by placing one side of you car onm a curbside.
    713
    problem with that is if he drains the coolant, since the car is on the curb at an angle, not all the coolant will flush out.
    USDM Bodykit
    USDM Foglights
    Eibach Springs
    W210 mirrors
    Aahhh yes. Then ramps and stands it is!
    639
    Thanks a lot for all of your help and answer guys. Actually I'm looking to find some piece of wood to put under front wheel, with factory jack. I belive that this should be enough and also secure (car will be parked with rear end close to garage wall).
    Probably I have to lower and rise up two time, to permit correct flushing of engine block (due to raised position of front respect rear axle).
    What do you think?
    But my main question is: does someone know which size of bolt and if an open ended key will be sufficient.
    ...as far as wrench for calibrated tighten is quite impossible to operate: too long
    Hi to all
    Marco
    639
    Hi Guys, sorry if I always press you but, since I plan to do the work (as described in my above post) tomorrow, I will appreciate a lot your help.
    Does someone have really already done that job? Because my friend (that work in a garage) kindly suggest me to avoid any engine drain block removal, due to possible breaking because of encrustation on the plug and relevant thread.
    He suggest me to remove the lowest hose pipe that in that case should be the radiator plug I belive.
    I'm wondering that only the radiator plug will be not enough to well drain all the coolant.
    Because car, I'm quite sure, are still with factory coolant (from 1998) I really want to drain as much as possible, considering also that MB technician said me that previous MB type apporved coolant was different from the kind utilized now
    blue
    plese help me
    PS: I bought 4.5 l of new coolant that I intend to utilize at 50% ratio with home drinking water.
    When I drain the coolant in my car i just undid drain plug at the lower end of the radiator. I didnt even raise the car up to do this.
    All I did was make sure the car was at operating tempture to make sure the thermostate was wide open. Undid the plug let it drain.
    639
    thanks a lot
    Thanks a lot Nokia you are a friend for me.
    You have suggested me a good alternative: let the engine heat to open the thermostate and than open the radiator plug (that I belive is really easy to operate removing the underside plastic cover). But are you sure that thermostate will be well opened to permit complete flushing?
    So I have to operate with hot colant, paying attention to avoid hand burning
    ...But being the thermostat above the engine, is it really requested that this need to be open? May be the radiator plug is really the only one plug to utilize.
    Wondering because the engine block plug does exist if so.
    in any case thanks again.
    Marco
    PS: please how much coolant and water have you filled up? Your is a 6-cil?
    The only thing you need to do is undo the drain plug on the rad, whatever comes out is good enough.. mix your coolant 50/50 and you should use about 7.5-8L, 4L of MB pure coolant mixed with water = 8L.
    keep some of your old coolant to use for topping up if needed.
    the drain plug on the side of the block is hard to ge at (need a hoist) and is only used when removing an engine from the car to drain the coolant left in the block.
    whatever comes out from the drain plug on the rad is sufficient.
    and this would be a good time to replace your thermostat also... its probably never been done and a great time to do it.
    once coolant has been filled back up, run your vehicle to temp, either by letting it idle or revving the engine @ about 2500 rpms until the temp gauge hits operating temp and goes above slightly then returns back to normally operating temp. leave your coolant reservoir cap off during this process, and your cooling system will be bled.
    top up as necessary and you are done.
    639
    Thanks a lot SLAMMED_C, your reply is very usefull for me, so the remaining part of coolant in engine block is a really minimum part. OK
    Please do you think that the suggestion made by Nokia8860 : "make sure the car was at operating tempture to make sure the thermostate was wide open. Undid the plug let it drain" is it better or not necessary.
    Do you suggest to change thermostat also if it work always very good?
    Thank you very much
    Marco
    PS: I've used "search" and I saw that is suggested to activate defroster after coolant filling up. What do you intend as "defroster"? the internal heating? To clean the cooling system I simple put water from the expansion tank to flush, water will come out from radiator plug?
    The reason why I run the car to operating tempture is to have the thermostat open so that when i undo the drain plug i get some of the coolant that is in the block itself.
    If you just undid the plug while the engine is cold then you would only get what was in the radiator.
    However has slammed pointed out draining the radiator is good enough.
    Hey take pictures of the process and email it to me so others can benifit
    also, just fyi, here's another good thread on coolant.
    http://www.club202.com/forums/showth...=coolant+flush
