Cleaning with industrial degreaser
and then sandblasting
Etienne
Any recommendations on how to prep them? just some light sandpaper and cleaning? that would be my best guess...if so any recommended grit?? thanks!
99 c280 (WHITE)
In the midst of modding.
Etienne
degreaser no problem but if you just happen not to have a sandblaster laying around....? =)
99 c280 (WHITE)
then sand manually, but I doubt you'll be able to do a good job manually since it's not flat and there are many little hard to reach parts.
The grit doesn't matter, use coarse in order to clean it well. It's not like youre sanding wood, you won't worn the part.
Etienne
Clean it as much as you can. Let it dry completely. Then mix the paint in the amount that you would use coz it dry's up easily.
im just going to use the ford engine red spray paint.... from what ive heard/read this should be ok (about 3-4 coats) am i right? or should i be using sumthin else? thanks!
99 c280 (WHITE)
Thats what I used.. Ford red engine heat paint.im just going to use the ford engine red spray paint.... from what ive heard/read this should be ok (about 3-4 coats) am i right? or should i be using sumthin else? thanks!
I did 2 coats.. but now it doesnt look as bright as it once did, so tou may want to try more coats.. or use the caliper paint from foilatech.. a buddy at work used it to paint his calipers and they came out really nice.
I used a wire wheel to clean my calipers before painting..
i used ford red as well..my calipers lookED good, but now theyre covered in dirt and stuff. i am thinking about painting them black to add depth behind the rims.
i recommend the GT caliper paint that tirerack sells
i've used it on 2 cars, very nice and glossy and kit includes prep sprays and wire brush etc.
yeah i saw the g2 kit on ebay and was gunna ask about it... maybe ill go that route instead...thanks!
99 c280 (WHITE)
just use a wire brush and a good cleaner such as a solvent or even use gasoline to clean them, or diesel. they are the best cleaners... thats if u dont mind the smell
