Results 1 to 12 of 12
Thread: Weight of Stock C Class Battery?
    What is the weight of the stock C class battery that sits in the trunk?
    hahah smart ass response...
    take yours out and put it on your bathroom scale.
    ahhahaha
    Maybe around 25lbs or so?
    Jun 2003
    397
    Battery Weight
    ahhahaha
    No it is closer to 35 - 40lbs, It is a big sucker and mine is a maintanence type, have to check the fluid level once a month and usually a cell or two needs fluid. this is the 2nd battery, the original was replaced under a recall last July, but you got to check them regulary.
    Benzmeister
    1999 C280
    Recall? on which vehicle?
    Jun 2003
    397
    On C280 98
    to 2000 I think. I'll look up to make sure and if this is wrong I' post later today.
    Benzmeister
    1999 C280
    Jun 2003
    397
    Re: On C280 98
    Also, I got an extended warranty on the V6 engine for 150K miles, did you folks know about that? It seems Daimler Benz didn't tell their dealers to use syn., oil only in this engine and a few had problems. Now the oil of choice is Mobil 0W 40W.
    Benzmeister
    1999 C280
    Re: Weight of Stock C Class Battery?
    Why would you want to know the weight of the battery anywayz??
    Re: Re: Weight of Stock C Class Battery?
    most likely for reducing weight of the vehicle.
    The stock battery weighs 56 lbs. That is one heavy battery.
    The battery I am going to replace it with is a dry cell Odyssey battery that weighs 26 lbs. The PC925 model.
    Theres 30lbs more to the total. So far my C43 has lost 150 lbs if I add the battery. I think I can lose about 225 lbs without too much difficulty.
    Edit, Link to site: http://www.odysseybatteries.com/auto.htm
    833
    Haha, you're sheading it and I keep putting it on! I just added another battery!
    you guys are like matter and anti-matter to each other. Hope you never meet, or kaput!
    Why did u add another battery?? Do u have a big sound system??
