Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
Thread: Rear light under front seat (as per Steve re-Design)
    639
    Originally posted by MBenzNL
    It does come with the wiring and connector...it is 1 piece...
    greetingz,
    Thanks Steve for this confirmation. I'm still waiting because local Stealership was not provided.
    I'm curious to see the light that LED will emit. Respect the white LED I've just received from superbrightleds.com, this seems to be more similar to standard filament bulb.
    639
    Originally posted by Corey
    OK, this thred has got my attention. Sounds like a mod I'd be interested in. Pictures please!
    As I said, I'm sorry!
    In any case, for your information, I'm planning to connect them to boot fuse box, to external position (european standard) light.
    I'll decide as soon I'll receive components.
    ...some pictures of the light that is being talked about here:
    this is how flat it is:
    [img]http://groups.msn.com/_Secure/0RgDYAmQVrQM88FJeUY4alzYVVpWZky6x*AjhYUvkGSS82u1G8 x6D9w8LukZSWx*tfkCD!EayRAqCLbDmX2iZoFWgtUq3gZJVDzd N7T9VMlE/stoellamp01.jpg?dc=4675441858516095770[/img]
    light off:
    [img]http://groups.msn.com/_Secure/0RgDKAmYVIQQ88FJeUY4al!KY*VOeiV1Dc1!*zj*7DnHe4EZLD gI2GZ4LKjG0IvsoMwxfVRM83n1xpMnzh0wQvCD7XzMPJS1sHuK TTTy69ck/stoellamp03.jpg?dc=4675441858523549925[/img]
    light on:
    [img]http://groups.msn.com/_Secure/0RwC8L5cV9BM88FJeUY4al74tMFoOkoI7uKkhBdjCL97e0GPJ2 EclSWa5DgmzRKPP3FBuJV0yB83QI*DJvTF!Mo2bNOWWMiA31OU Dv6Zk*Y8/stoellamp040.jpg?dc=4675441858529712407[/img]
    ...the clean carpets in my 555k kilometer C250D:
    [img]http://groups.msn.com/_Secure/0RgDnAmgVlQQ88FJeUY4al6mS29B7cOFYwYbdFetkKRk171qQh TDEvPn5uvvJYr37pKrnWIyHu!0sX2tRScuyIBmIHa3azRx0*uU ZLerarR8/stoellamp05.jpg?dc=4675441858538365971[/img]
    greetingz,
    1993 C250D with 600+k kilometer AND cause of 2 confiscated driving licenses * DIESELpower pur sang
    www.MBenz.NL
  4. #29
    639
    These photos are much appreciated, thanks a lot!
    Does the material you've cutted is leather or plastic? Mine are is as per european "elegance" standard (not leather). Hoping that cut will be possible as well.
    Do you have dismounted the back of the seat to install and pass the cabling? I'm quite sure it's not necessary.
    hi
  5. #30
    639
    For your information guys: the two led lights are just arrived. I've not installed yet, but I've just connected to a 12 V source. Their light is very dim! It seems not so useful.
    I'm planning to connect to the exterior light, please what do you suggest me: to connect directly to the front fuse box (to external european light) or to other internal connection (i.e.: by a relè connected to a 12 v source as the lighter socket and controlled by the light cable from ISO radio connector)?
    thanks a lot for any help
  6. #31
    It is PERFECT! you'll see once you installed them...you don't want any bright light underneath the seats, do you?
    greetingz.
    www.MBenz.NL
  7. #32
    639
    OK thanks a lot for your important clarification. Do you think it'll be useful also if I install other two in the front foot area?
  8. #33
    639
    Hello, after a lot of time, yesterday I had some free time to perform the installation. At the moment I've passed all the necessary cable but I've installed only one light. My 12V is a permanent source, as done by Steve, but my question is:
    how does Steve have obtained the "dimming feature"? Have You installed a dedicated capacitor?
    Please be so kind to inform me about.
  9. #34
    dimming???
    greetingz,
    www.MBenz.NL
  10. #35
    639
    dimming???
    greetingz,
    Sorry may be I'm wrong, but I was wondering that your were provided with gradual turn off feature.
    But I think I'm wrong.
    thanks in any case.
    Mine. beeing connected to a permanent 12V source, when I turn off, some few intermittent lamps still persist for some seconds, so I'm wondering to add a capacitor to stabilize the volts for some seconds. Hoping my bad explanation will be clear. thanks also for this.
