Results 1 to 2 of 2
Thread: engine codes question
    Jun 2003
    3
    Hi all
    My 99 c280s check engine light came on today.
    I scanned the codes and retrieved a code # 173
    The car seems to be running OK.
    Any ideas ?
    1999 c280s
    1987 Volvo760TW
    I have to look it up..but here is the general format of OBDII codes.
    They are usually 5 alphanumeric codes.
    First one is always one of the following:
    B = Body
    C = Chassis
    P = Powertrain
    U = Network
    Second is a numeric of 0 (zero) or 1 (one)...
    0- SAE (standard)
    1- manufacturer (additional code put in by perticular manufacturer)
    Third is the most imporant digit.. 1-8
    1- Fuel and Air Metering
    2- Fuel and Air Metering (in fuel injection system only)
    3- Ignition
    4- Aux emission control
    5- Idle control/ aux inputs
    6- Computer/aux output
    7- transmission
    8- transmission
    The last two digits always come together.... These digits are the pintpoint code. It tells what exactly is wrong.
    In your case.. the full code would be P0173 - We know its fuel/air system. The 73 part, I have to look it up.
