Results 1 to 8 of 8
Thread: '99 C280 A/C display
    Ok funky stuff.. the display for the A/c gets all funky and unreadable. So I push it and then the display works right. So it's basically intermittent.
    wtf do I do now?
    2007 FJ Cuiser
    2003 E55 AMG
    Heat?
    check to make sure you buttons arent stuck. once i thought my controlls were broken cuz the lcd went funky.
    I soon discovered my auto button was stuck and a press to release made it fine again.
    so i would suggest make sure none of the buttons are stuck first.
    lol..happened to my OEM stereo too... HEAT is to be blamed.. the plastic gasket behind the button can get sticky especially if dirts get into it.
    Jun 2003
    3
    Our climate control LCD display also has an erratic display
    The dealer Is going to replace it N/C
    99 c280s
    1999 c280s
    1987 Volvo760TW
    Jun 2003
    397
    You can also try blowing some "canned air" around the switches, I did this to my stock radio and it works fine now. You can buy the stuff at Radio Shack, it is used to clean computer etc.
    Benzmeister
    1999 C280
    Member babycarlsson's Avatar
    Feb 2003
    Virginia
    93
    Re: '99 C280 A/C display
    wtf do I do now?
    Doc, I had the same problem in '98, definitely more often in the hot and humid day, nothing could fix it no matter what I tried... If you could get a dealer to replace it free of charge, that would be nice
    Jun 2003
    256
    The EC button on my climate control is always on. What causes this. My a/c compressor doent engage. Pls help.
