Results 1 to 11 of 11
Thread: C36 foglight question
    willpower
    Guest
    I've looked but can't seem to figure out how to get to the bulb in the lower foglight housing. And correct me if I'm wrong, but it's an H3, right?
    In Charge
    Left Lane
    4,534
    To get access to your fogs, you either have to take off the bumper or jack it high enough to get under there. It is probably easier to get the bumper off and then remove the fog.
    You can look up your fog bulb in the owner's manual. Dont know off hand.
    1998 C43
    1994 C280 (Retired)
    Yes!! H3 are commonly use for fog lights.
    E55 2000
    M-3 2014
    San Francisco, CA
    2,827
    What I did was take out the front bumper, and then take out the fog light.
    Underneath the fog light, there is 1 or 2 screws, then you can have access to the fog light.
    713
    hehe you need to take off the front bumper to replace the fog light?
    I didn't hehe
    Autostart Autostarter
    Progress Rear Sway Bar
    USDM Bodykit
    USDM Foglights
    1997 AMG C36 (RIP Thank God)
    OEM Bosche Clear Corners
    OEM AdvanteGarde Grill
    Bilstein Sport Shocks
    Eibach Springs
    Zender rear lip spoiler
    W210 mirrors
    San Francisco, CA
    2,827
    hehe
    My car is kind of low and then I don't have access to hydrolic lifter in the shop...
    with my own hydrolic jack, it is not high enough to access the foggies
    SUV RULE!!!!!!!!!
    E55 2000
    M-3 2014
    willpower
    Guest
    oh man... this is looking to be a PITA of a bulb change... oh well, is there anything I should be careful of when taking off the bumper? and about how many screws? (sorry to ask so many questions... )
    Approximately 8 million screws. 2 million on both sides and 4 million in the center.
    E55 2000
    M-3 2014
    willpower
    Guest
    could I perhaps jack the car up onto stands and lie down underneath to change it? Or would that be potentially disastrous?
    San Francisco, CA
    2,827
    Let's see bro,
    - at the front, there are 4 big nuts. 2 behind the grill to cover the fans and 2 behind the tow hook covers.
    - You also need to take out 3 bolts that holds both brake duct
    - on each side, close to the fender, there are 2 screws that you need to take out.
    - Once every bolts are out, get your hand inside each side. There should be a little lever that you need to push and then slide the bumper to the front.
