what is the sensor film?
unless you damaged the sensor film, the CEL will not come on because of it.Originally posted by Ashkan's C280
does this turn on a check engine light? I really hope I didn't ruin my mass cause my check engine light just came on after I did this, like 20 miles after.... DAMNIT
nenad
2002 S500
2002 CLK430 w/ 5.5L swap
2002 SLK32 AMG
2003 S430 w/ 5.0L swap
2000 ML55 AMG
***C43***
LMFAOOriginally posted by Ashkan's C280
You problay broke the acuall MAF sensor
yeah I guess so, oh well after 94k it was time for a new one anywho
***C43***
Originally posted by fastmayte
hey, what kinda benz u got? 280, 230, 220, 230K, 36, 43???
if u press the accelerator a bit, does the engine rev up or do u gotta press it alot for the engine to start revving up?
on my c220, i had to press the gas all the way to the floor before it'd pick up, this was because the throttle cable was loose, u can hand tighten it your self on the throttle body, just follow the cable to the end, u see a plastic screw.
check your fuel filter, plugs etc like 714guy said.
This actually helped out a lot. Although for my car it was not easy. I had to use pliers to tighten it. The worst part I barely had room. My throttle response is waaaaay better.
Thanks!
