Cupkit? Coil Over?
Ok so its time to upgrade the suspension of the 95 c220...
I have Drilled front discs, rear discs, new pads around, e-brake, front axle repair kits, bilstein shocks... ready to be installed.
I also have.. a set of C280 springs to be cut (I chose C280 because of its stiffness compare to C220 OEM springs), Yeah I know you aren't supposed to cut progressive springs.. but I've done it to Audis and VWs with good result for the cost..
However, on the way out of the parking lot, I saw a nicely tuned Subaru Imprezza.. I pulled over and chit chat abit. The owner said he lowered it with coil over and suggested the least I could do is H&R CUP KIT.
Although i have known and seen these kits, I personally havent had any experience with either of them. I have cut my own springs all this time. Suggestions, comments on cupkits or coil over?
Keep in mind..COST effectiveness is priority. And for a 4 banger, I am going for look rather than performance.
