Results 1 to 11 of 11
Thread: Puddle light under front doors (5W light)
    Mar 2003
    639
    Is it possible to install 10 W instead of that candle for the dead 5 W? without burn cable and/or fuse?
    If you do that you will draw more current from the circuit. Other things on that circuit will behave funny. It would work for a while but you might notice problems after a bit.
    Mar 2003
    639
    thanks a lot dumpsta. So it seems that is better to avoid.
    thanks
    The current is less of a problem then the additional heat of that bulb is...
    greetingz,
    1993 C250D with 600+k kilometer AND cause of 2 confiscated driving licenses * DIESELpower pur sang
    www.MBenz.NL
    Mar 2003
    639
    ...but that one is very poor!
    thanks again for your reply guys
    May 2003
    199
    You could always look into LED's
    May 2003
    1,669
    what is a puddle light?
    Open one of your door and a light would come on underneath your door. That's the answer for your question.
    E55 2000
    M-3 2014
    May 2003
    1,669
    howcome i dont have them?
    May 2003
    1,669
    is it because i dont have the leather package?
    I also don't have that puddle light so what I did is search for the illuminated door sills and that's my puddle light.
    E55 2000
    M-3 2014
