as far as I know, no. the shock shaft wont extend fully through the perch, and you wont be able to tighten the shock.
nenad
I was wondering if there was a way we could run a centimeter or two thicker bump stop to further shorten the stroke of the shock absorber. Just looking for a solution to bottoming against the wheel well on extreme dips during hard turns. Speedy? Anyone?
-Ray
2009 Audi S5 Quattro
nenad
2002 S500
2002 CLK430 w/ 5.5L swap
2002 SLK32 AMG
2003 S430 w/ 5.0L swap
2000 ML55 AMG
the bump stop is on the shock shaft and doesnt have any influence on the bolt design on the top of the shockOriginally posted by jnenad16
nenad
i cant see why you cant buy another bump stop and cut it to the length you require and put it on the shock shaft aswell as the original on each side.
but my advice would be to just do some panel beating or cutting of the liner of the rear guard, or run a spacer
-Logan-
come to think of it a bit better,you are right, I forgot there is a machined groove and a washer that limit the shaft from extending too far, so this allows for extra room. my bad on previous post, I was too tired.Originally posted by c280nz
nenad
2002 S500
2002 SLK32 AMG
2000 ML55 AMG
