Results 1 to 6 of 6
Thread: Pads
    Feb 2006
    11
    Pads
    I keep reading though everyone's threads, which are extremely helpful by the way, and I see people mencioning pads in conjunction with springs. What are pads and what do they do for adjusting springs?
    In Charge martattack's Avatar
    Jan 2004
    Kirkland, WA
    816
    It's basically a shim that fits between the top of the spring and the upper spring seat. They vary in thickness so compensate for different optional factory equipment. We use them to slightly adjust the ride height.
    Check half-way down this thread for the part numbers.
    http://www.club202.com/forums/showth...ng+pad+numbers
    2012 535i
    2005 545i - Retired
    1994 C280 - Retired
    Feb 2006
    11
    Thanks, If I go with the H&R/Bilstien combo, would I need any pads?
    Jan 2004
    Kirkland, WA
    816
    You already have spring pads. If you wanted to raise it or lower it a little, you could pick up some thicker or thinner pads.
    2012 535i
    2005 545i - Retired
    1994 C280 - Retired
    you def need pads just the matter of how thick.....(aka how low do you wanna go)
    hummm sounds like we are talking about something else lolsssssss
    cant afford a mercedes......
    that\'s why i have a bimmer and an audi
    I've found that the pad thickness (#1 thin vs #4 thick") affect the ride quality. The #1's allow for a biut more viobration and harshness while the #4's really smooth things out.
    Hotbasco...
