Results 1 to 8 of 8
Thread: engine revs bounce
    engine revs bounce
    I'm having an issue whereby the motor drops revs very briefly and then rebounds. Happens every few minutes independent of AC or accessory operation. Last week I noticed the dash lights would dim just before the revs dropped. Shop foreman immediately diagnosed it as a bad alternator and replaced it. The readings were 10.5 volts over 8 amps, and he said it should read 13.5 over 80 amps. So the alternator was failing, but the car still does this, though not as often. I don't have any ideas.
    Jun 2004
    19
    I have noticed the same thing with my car. I've only noticed it when the engine is at idle. Hasn't caused any major problems though.
    I don't know what's causing it either.
    1998 C230 - Magma Red
    Pioneer in-dash CD
    Bosch clear corners
    H&R springs
    18x8.5 Monoblock VI replicas (black)
    Dec 2003
    587
    I have a bran new alternator my car dose the exact same thing there is an electric pump that clicks in i think it controls the cooling or a/c
    This might not be related, but My car used to idle rougher.... sometimes hit close to 500 revs.
    However, I just did cylinder head gasket replacement, and other gaskets, my idle is ALOT smoother and runs around 650 now.
    Paul
    mine bounces alittle at idle to,hasn't caused any problems though.
    Susanto, how could you pull the head and not let me port it for you??
    Arrrhhh
    Paul
    Arrrhhh
    small question,is there much gain in porting the benz heads?mines a 97 230k?? thanks
    yes dont hi-jack the thread!
    2,283
    Is "normal" idle supposed to be 650 revs? Is this in park or drive? mine is 500 rpm in drive at a standstill. It has always been this way since I bought it so I have no reference to what normal is.
    My car kinda does the same thing, but I don't notice any lights dimming. Just drops a hair from 500 and feels like it will stall sometimes. Very frustrating.
    Do our cars have any components which directly affect idle? Is there any way to fine-tune idle in our cars?
