THe kit comes with a Garrett AiResearch T-25 turbo, that has an adjustable external wastegate that you can adjust to turn up the boost. I think you could probably turn it up to maybe 6psi or so, which is not that much. I had mine running a little more boost but I think that a former member here blew his C220 engine at around 7psi with his turbo kit (he later rebuilt it). I would not want to risk it.
If you really wanted to crank it up, it would cost you money. You would have to get forged pistons/ rods, perhaps sleeves (though I think the C220's tough block might not need them), and bigger injectors for extra fueling.
