There are hundreds of threads on this, as soon as you click that search button on top... iits red for a reason..! hope i helped a little bit.
I have 1g to spend on performance mods, any ideas? 1999 C230 Kompressor, all stock!!!! it needs to eat civics alive!!
Jim
>> My white Greek merC
i was in your position a month ago...but i figured im either going all out on performance, wich would end up costing me a loot...or i can spend it on something else...i ended up buying a whoop ass sound system
Thats what i was thinking about, killer sound system or just make it go faster. i went from 5.7L Z28 Camaro to 4 Bang-er Benz. the benz is pretty nasty for a 4 bang-er btw. as of sound system did anyone do the sound system there self, if so can you please pm me. lol kinda sorry for the useless topic now, new to this place.
bah why waste it on music, if it were me I would spend it on some limited slip belts, a performance pully, and a bigger vortec blower all together.. then a k&n panel filter, some v-grove plugs, you could still get a great p3/wma/sd+bluetooth headset, plumed into what is a great sounding 6 channel speakers..Originally posted by Cru328prod
place.
give her some projectors+clear corners and sexy tail lights
Im sure you can achieve it with your 1000 green backs.
Standard 1999 C230K Sport
Mileage: 120K
Tyres: Pirelli P6000
Question is were do i get all of that, i want to gain aleast 50 - 100 hp. im still trying to figure this engine out with the blower.
get full-on custom exhuast and try to manage to afford an intake as well.
50-75 shot nitrous, then the rest of the loot on a nice head unit. or send me a grand and i'll show you how to
S/c pulley (do they still make em?), reprogram of ECU, and if you can exhaust with high-flow cats.
If im not mistaken, that engine can't handle nitrous. forged pistons are needed
well in that case, FMIC with no2 spray barOriginally posted by Cru328prod
a guy with a 230k has a nos express system on his ride, and Ive read somewhere the m111 can handle "50 shot" stock.. if its true that could be some cheap hp right there..Originally posted by rman
Mileage: 120K
http://www.aspracing.com
look at the crank pulley for the '98-99 M111 engine block. good for at the very least 20hp at the wheels. Would cost you about $1000 for the crank pulley, cold plugs, upgraded fuel preassure regulator, and new S.C. Belt.
After that you can make a custom silicon tube to relocat the MAS to a horizontal position instead of vertical coming off the I.C. to greatly improve the throttle response and torque from the 2500-3500 rpm range.
Solid results that does not comprimise the longevity of the engine or supercharger. (raises boost from about 5lbs stock to 8-9lbs of boost.
well said, I could live by that for my own road map on the performance front. that site has you wishing you could get the ac eliminator pully and perform other such blueprinting on the pully system..Originally posted by Proven Guilty
Mileage: 120K
Get ASP pulley. You won't be disappointed. All for under $800.Originally posted by Cru328prod
You probably eat a Civic alive on the freeway... But against transplanted/ forced induction civic, it would be hard....
Ok lets say i get that pull upgrade, do i need any kind of special tools? and how difficult would you say it is?
it's all been covered before.
it sounds like you really need to do some homework before dropping cash. the red search button is your friend; try searching for asp pulley, pulley kit, kleeman pulley, and pulley removal. etc
yea i know was kinda being lazy, sorryOriginally posted by Proven Guilty
Being lazy will not get you far in terms of looking for answers. Many people do not respond to questions that can be easily found with Search.Originally posted by Cru328prod
Not only that, it's just best practice to learn as much as you can about what you're trying to achieve. that way you will know what results to expect, and how to troubleshoot when something doesn't work as expected.
Personally I never trust the opinion of a single person. Your best bet is to find as much information as possible about the pros and cons and decide if its end result will be meet your goal and expectations. This way you're not stuck in a situation where "so and so said it would work perfectly" and come to find out they already upgraded a fuel preassure regulator and forget to mention it. In result, your car ran too lean and burned a hole through the top of the piston etc etc
