This might help:
http://dieselgiant.com/Mercedes%20fl...%20failure.htm
PS. Did you check your ATF to determine if the level is correct? Or are you just hoping ithe problem will go away?
Ive never seen them myself.. but I have heard of a couple.Originally posted by benzonline
I say in September or sooner I'll do it then.
Ross have you seen many that broke apart?
This might help:
ATF is fine...the dealer did the tranny fluid change and this week there has been no harsh downshifts at all.
99 C43 AMG
99 C230 Kompressor
Great to hear that. Thanks for the feedback!
Front flex disc being changed tommorow! The downshifts are sometimes SLAMMING that I said "eitheir now or never"and I dont want to leave it parked for most of the winter knowing things need to be changed.
99 C43 AMG
99 C230 Kompressor
