Glad it helped Paul.
You want a wire to be able to tell if the engine is running so that when it isn't energized you can energize a circuit to trigger the AC pump.
If I understand you, wouldn't a feed from the alternator be your solution?
I don't really think I completely grasp what you want because in trying to imagine the design of your circuit, it seems a little complicated. But considering the things you have managed with your engine, I put NOTHING past you.
12V from alternator energizing a relay keeping it open. When the 12V disappears, relay closes, activating 12V from the battery to another relay which is controlled by your turbo timer.
,Na i dont have cruise control!,iv disconnected most of the wires between the engine and oe ECU,which only leaves the cam/cranks sensors + 3/4 other wires and the CAN system still connected...its possible one of those wires is and engine on,or its sent over the CAN system.
