No no no no no non noonononoNONONO hahahaha........ i want to stick a needle in my eye^^. I have said from the begining of the thead..as nicely as possible at first^^ but i'll be more to the point.... >>> it is near pointless turboing it if your not going to investigate the cam setup,If you dont investigate and it results in bore wash you will forever fill your oil with fuel and slowly but surely kill your engine, it will also create tuning problems. There is a chance that if you have external exhaust recirculation your overlap may be much less and you may not need to change cams but only adjust timing...either way YOU NEED TO DEGREE IT TO FIND OUT,then YOU NEED TO TALK WITH SOMEONE WHO BUILDS CAMS,LIVES ON CAMS,SLEEPS WITH CAMS,EATS CAMS,IS A CAM....hahaha geez iv just lost it these days.
