3. Filter and Drainage
Located under the driver side (US) of the car will be the oil drain plug.
Will look like this when removed. Has a small washer.
Loosen the oil plug and drain the oil into a clean drain pan under the car. The plug is located on the side of the oil pan. Let the oil drain and proceed to work on the Filter.
(The bolt is covered by the wrench adaptor)
