could it be the deck itself? pack some foam under it.
Is there any way you can tighten up tye rear deck speakers? My subs rattle the shit out of them. Ive tried to just turn them as tight as i can but they are still loose
"anyone can drive a new car, it takes a true enthusiast to breath life into an older one"
\'94 C220
Black.
Chaos reigns within.
Reflect, repent, and reboot.
Order shall return.
You should just remove them, if you get quality front and rear door speakers you wont need them. plus you'll get much more bass in the car because they will act like air ports.
loctite?
What is happening is your subwoofer is pushing sir up against your rear speakers and have caused them to probably already rip which it causing the rattle.
get polly fill from wallmart like $3 for 2gal of fluff shove it in there
then make shure your 3rd break light wont rattle
Polly fill ill have to check that out I'm having similar issues just the rattle on the 3rd brake light is my main issue how would you go about fixing that? I haven't really messed with it yet I hear the plastic on the 3rd brake light can get very brittle.
Maybe applying some hot glue and shoving the 3rd lamp back in before it dries so it removes any play within the housing?
1986 201.034 5-speed, Evo II wheels
1986 201.024-w/ 3.2 M104 engine, 5-speed Conversion
Cotton balls between the front and back pieces where they connect on top did the trick for the third brake light.
see I didn't want to shove cotton inside my 3rd break light as it could catch on fire easyer I like the glue trick but if you have to change the bulb .... lol
You bought a new Scion...pretty hard to justify that one. And you type like an illiterate.
Hush down gents... Consider yourselves warned.
but I do avoid lights with itmy exauhst is so loud I needed to dampen it
I am new to your club most interesting, likewise I don't think cotton around lights is a good thing. If your putting a loud system in a 202 why not change the third brake light to an LED strip high on the rear window looks good. My opinion for what it's wurth
