sharp tink noise frin under car
Went to work fine leaving work I Went over a bump on the left side and I heard a real loud Klink noise though Maby a ball joint was going or a hub looked real quick and everything was attached still so I proceeded home trying to replace the noise it only does it under throttle and making a hard turn or slow and over a bump
started swerving at 20 and I get a noise on the right side instead
and under serious throttle I can now feel a slight vibration going 50-70mph
Vibration thru shifter and steering wheel
Hey man,
Have you checked your engine mounts?
Cheers
I'm 90% positive it's my exhaust when I kick my muffler it makes the noise in the front of the car
Good find, jack it up and check all the flanges/fixings and rubber hangers!
I would suspect the driveshaft flex discs are worn and causing vibration and possible slop enough to hit something when the suspension is bound and moving under cornering and thrust loads.
Just wait til the front flex coupler comes apart and your driveline sawing up your transmission tunnel at 80mph and hits the airbag module right next to the shifter, blows the airbags in your face. Funny shit right there!
Good enough reason to check your flexi couplings while under there
lol remolexi .... bet that was fun
