You dont have much room but all you can do is try. I havent replaced one in a long time. If not then youll have to drop the rear part of the trans by removing the trans support, disconnecting the flex disc at the trans, move the drive shaft to the side and you should have enough room. If you still need more room you can always jack up the engine by the oil pan (small piece of 2x4 in between jack and pan) that should drop the trans even more. Hope this helps.
