Results 1 to 25 of 49
Thread: The dreaded head liner sag
Threaded View
  1. #28
    Aug 2012
    SoCalif
    1,011
    So far so good. I need to do the pilars next. She wanted that posh look. Kind of like her Gucci bags I guess. It actually looks really good next to the other interior colors. Gives it a little Rodeo Dr.(Beverly Hills) feel...lol.
    EDIT TO ADD INFO: This is Burlap from JoAnn's Fabrics (Thank you again Den for the discount coupon). The burlap does not stretch hardly at all so it is real tough in the sunvisor countour areas, but with a little finesse it managed to lay down well/ The glue I used is the 3M Super Trim Adhesive Yellow (Automotive). It was very nice stuff to work with. I sprayed two coats on both sides as per directions. 3m also has a "headliner and trim adhesive- ( also automotive) but is not as heavy duty nor as heat resistant but it allows more working time. This Super Yellow stuff you have to work quickly and with a buddy system- do not try it yourself- too hard to handle for one person. The headliner adhesive gives 60mins working time, this heavy duty stuff sticks on contact and only allows for about 20 mins tops even thought the can says 4 tact, 30 mins working time.
    I started by laying the material flat upside down, spaying it completely once, then the headliner backer board- that used almost one full can- then immediately went for the second coat right away. Gave it about 2 minutes after that and started to assemble the rear center first(Since I finished the second coat there about 5-6 mins earlier and was already tacking), working towards the sunroof opening with both sides folded towards the center line still. I then went right and left off that while my buddy held the fabric up in front of the sunroof. Once that was tacked enough and rubbed in for about 5 mins, he grabbed one side up front and I grabbed the other corner as we each pulled and pressed around the sunroof opening to meet in the front center. LF and RF tabs of the fabric lay over in triangle form at this point I started working the dome lamp and visor pockets until the entire fabric lay in place.
    The beauty of this yellow spray is that the burlap is somewhat see through with mesh type square openings. The glue is pretty much the same color as the fabric so any bleed through was not an issue- nor was too much build up of adhesive. It really bits in place after about 10 mins tact time and is stuck dry in 20 mins. The can says 48 hrs "cure" time so I will keep it in the cool garage out of sunlight for another week, then I will install it.
