you dont even touch them so don't worry. if you only gonna to change the front pads then your will only touch one bolt, the bottom one that holds the calipler, but if you change the rotors too then you'll touch 4 bolts, 2 holding the caliper bracket and one screw for the rotor and that other caliper bolt mention earlier.Originally posted by C280 JR
now that im on my break, im thinking of changing the pads in the front, do i have to do anything with the lower control arm bushings, or any bushings, that can damage them
Elvir
Good luck
